If I remember correctly, that has to do with features introduced in newer AMD GPUs that aren't found in those that aren't the newest GPUs/APUs. That's because the same driver is used for all AMD GPUs, be it old or new.
That error just tells you that it couldn't find those new features available in your APU, but it will work perfectly fine and not suffer any type of lag nor unstability because of it, so you can ignore that with no problem
Ok thanks for that.
What did You before that Warnings appeared?
New install update and upgrade than the error see in terminal with firmware error
You can read a bit more here:
Thanks m8 i will try en let you no if it is working
