Hello Guys.
I have a problem with Wi-Fi on Zorin Os 16 Lite.
I installed Zorin Os on my laptop, but i have a problem
OS don't seeing Wi-Fi [wireless net]
How i can solve ?
Sorry for my bad english
Thanks
Hello Guys.
How i can solve ?
Thanks
Hi,
Do you have the means to connect with wire?
reboot
2 Open "additional drivers" in Zorin menu, eventual search for driver then it will appear. See if there's a driver available.
Okay, thanks
I will try.
I have a problem. My laptop don't have ethernet port, below is the network card model
Maybe I can install the driver without internet?
Model: Realtek 8821CE Wireless LAN 802.11ac PCI-E NIC
You might want to check this: networking - How do I install drivers for the RTL8821CE Network Controller on Ubuntu 20.04? - Ask Ubuntu
Can you use your phone to connect your laptop to the net?
Also remember to disable secure-boot in BIOS.
Oh.. Okay, I'll try, and report you
Yes, I can
Thanks, but I decided to just connect the phone to the computer and turn on the modem mode. I hope your methods help others.
