Wide gamut monitor - sRGB clamp or ICC profiles not working
I have a wide gamut monitor (AOC 24G2) and colors are saturated under ZorinOS. It seems to be related to a sRGB clamp mechanism not being applied. I tried a lot of things but can't seem to find a working solution. Both x11 and wayland seem to have the same issue.
I tried applying the icc profile found here but it doesn't make a difference : AOC 24G2 Review - RTINGS.com
Under Windows, I would correct this problem in the AMD Drivers settings. Any idea how to fix this ?
So, when You go to Settings>Color and choose there a Profile for Your Screen, it doesn't work, yes?
