I will try that, but I have fast boot disabled on windows. Even the pagefile is disabled. I don't remember having checked if there's sound in the zorin live. But yesterday I installed Fedora 38 and it had sound. I don't like Fedora 38 so I gave zorin a chance thinking maybe since I had fixed the touchpad and wifi problem now I could do something about the sound. I am downloading w10 now to run it and see if the sound comes back to Zorin.
After googling and doing everything I could, installing like three ubuntu based distros I decided to move to arcolinux with the latest kernel and now the audio works. I don't know why it doesn't in ubuntu/debian based distros but I won't waste more time looking for a solution.
All Kernels have no sound, yet all arch installs that I've tried have sound. As for Mate, I just like gnome. Well specifically I like the design consistency in the program, but I don't like that toolbar or even the full screen app launcher. But I like that all apps have consistent four rounded corners. I care a lot about design and that is why I like Zorin, but if audio is going to be a problem and no matter what solution I try fails I have to look somewhere else.
Also I have found that the GNOME compositor is the best compositor I've tried, if xfce used it I could see myself using xfce with gtk4 applications.
I am happy to report that I fixed the dummy audio problem but it was on arch. I am leaving what I did here in case anybody else has this problem:
I did a bunch of things but what fixed it was installing
sof-firmware and alsa-ucm-conf. After that I rebooted and it all worked. The only problem was the power saving mode was turning the audio on and off and producing an awful scratching sound so I had to install wireplumber and copy /usr/share/wireplumber/main.lua.d/50-alsa-config.lua to /etc/wireplumber/main.lua.d/50-alsa-config.lua
then do
sudo nano /etc/wireplumber/main.lua.d/50-alsa-config.lua
and edit the line
--["session.suspend-timeout-seconds"] = 5
into
["session.suspend-timeout-seconds"] = 0
then systemctl --user restart wireplumber and that's it
