Hi I did a clean install of Zorin 17.1 minimal. I've completed all updates etc but it seems like my wifi adapter is not functioning. Likely just drivers. Wifi adapter is an Intel® Wireless-AC 8265. PC is a Lenovo ThinkCentre M910q
any advice on trying to get the adapter working would be appreciated.
I've tried : sudo apt install backport-iwlwifi-dkms and rebooted
tried lshw -c network and it comes back with unable to read network - open {2: No such file or directory)
Did you have, or do you still have Windows installed as dual-boot?
Did you disable Fast Start in Windows? See this: Intel Wireless 8265 does not work in any version of Linux but works with Windows - Ask Ubuntu
Windows Fast Start behaves a bit like hybernation when you hit shutdown. There have been reports on the forum of Windows hanging onto hardware in such circumstances.
Hi I am not running dual boot. I haven't check if fast start is on in the bios I will check tonight when I am home and confirm. I will have a look at the link you attached and give that a try as well
Fast Start setting is in Windows, Control Panel>Power Options>What the Start Button Does.
I realized that shortly after I responded. I am not dual booting on that pc at all though it's only running Zorin
I am having the same experience with my ASUS TP410UAR laptop. I just erased Windows 11 to install Zorin. I will also relook in the BIOS if there is a Fast Start option.
Update:
- I disabled Fast Boot from the BIOS - no change
- I tethered my laptop with my cell phone and downloaded the latest update - no change.
- Laptop is less than 30 feets from my WiFi router.
Ready for some advice/suggestion
Second Update:
Finally got it working using a tip from another user responding to this WiFi adapter error. In short, the rather unusual solution was:
- shutdown laptop
- disconnect power cord
- hold the power button down for 30 sec
- reconnect power cord
- restart laptop
Not sure why this trick actually resolved my problem. Now back to learning Linux ![]()
