Wifi completely stops working after a few hours
Installed ZorinOS on my grandma's laptop and after the PC runs for a few hours, the wifi completely stops working. It can't find any networks, turning wifi off and on in the settings just makes the network list load infinitely. This seems to happen even when the laptop doesn't go to sleep, during active use.
Enabled the alternative drivers offered by Software & Updates and it didn't help.
(sorry for non-screenshot)
Feel free to request any extra information or logs, I'm not sure what diagnostic steps would be useful here.
Hi and welcome. My first thought on this was the possibility of power-saving being the culprit. To alter power-saving settings (please note Zorin 17 is based on Ubuntu 22.04):
" To alter Wi-Fi power saving settings in Ubuntu 22.04, the most effective method involves configuring NetworkManager to disable power saving for your wireless adapter. This is particularly important because Wi-Fi power saving can significantly reduce network performance, potentially dropping speeds from 100 Mbps to 20 Mbps.
The primary configuration file is located at /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf . To disable power saving, edit this file and set the wifi.powersave value to 2 , which means "disable powersave". The possible values are:
  • 0 : Use the default value
  • 1 : Don't touch existing setting
  • 2 : Disable powersave
  • 3 : Enable powersave
After making the change, restart the NetworkManager service to apply the settings:
sudo systemctl restart NetworkManager
Alternatively, you can use the nmcli command to modify the power save setting directly for a specific Wi-Fi connection profile. First, list your saved connections:
nmcli connection show
Identify the name of your Wi-Fi connection (e.g., "BELL060") and then run:
sudo nmcli connection modify "BELL060" 802-11-wireless.powersave 2
This command embeds the setting within the connection profile itself, ensuring it persists across reboots, even if other power management daemons like power-profiles-daemon reset the setting.
For a more permanent fix, especially if the above methods are overwritten, you can create a custom configuration file:
sudo mkdir -p /etc/NetworkManager/conf.d
echo -e "[device]\nwifi.powersave = 2" | sudo tee /etc/NetworkManager/conf.d/99-no-wifi-powersave.conf
You can verify the current power save status using the iw command:
iw wlan0 get power_save
Replace wlan0 with your actual wireless interface name, which can be found using ip a . If the output shows "Power save: on", the setting needs to be adjusted.
To edit a .conf file you need to place sudo nano in front of the path to the file:
sudo nano /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf
Once you have edited the file use the keys Ctrl+ O to write out the changes and press Enter to save the changes, then Ctrl+ X to exit. Please keep us posted.
Did You reboot after doing that?
oh sorry, forgot to respond but this seems to have helped. thank you!
