Hey, I was having a problem on Zorin 17.3 as the wifi was disappearing when my computer was suspended. We tried to troubleshoot this and it seems that this is a firmware issue (I have a Mediatek MT7921e installed). I change my OS to Fedora Workstation but I'm quite exited by the new Zorin 18 features (especially the web app display). Is there something I can try to make it work, such as installing a new firmware (no idea how to do it, I'm quite a noob) ?
I currently do not have Zorin 18 installed, but I can try on the test version on live USB, and then replicate this solution on the clean installation.
Let me know if you need more info ![]()
You could try if
sudo apt install linux-firmware
helps. This command will install the latest firmware.
seems that everything is up to date, there was no new install nor upgrade
But it does not solve my problem, sadly.
And you don't have this problem on fedora workstation?
no, the only problem I have is that my pc does not wake up after being suspended, that's basically the same problem but less annoying as I am slowly losing the reflex of suspending my pc and rather shutting it down, but if you have a solution, it will improve a bit my experience.
I think I'll stick with Fedora, and find a way to have Zorin feature in Fedora (like Office App in web).
If you have any hint on how to achieve that, I'm all ear.
Then, when I will buy another pc that's compatible with Linux (I'm thinking about a Starbook 7), I'll put Zorin if that's I want to use.
I guess Fedora uses a newer linux-firmware Package. I think, you can install a newer Version on Zorin, but tehre wold be the Question if this would interfere with the System and cause Issues ...
Web App Support with a Program, You can have on Fedora, too. Here are 2 Options available as Flatpak:
