znt
1
Hi all,
I cannot enable wifi as it is not showing up in settings.
Using rtl8821ce.
I already did these commands recommended in a other thread but it still does not work:
sudo apt install build-essential git dkms linux-headers-$(uname -r) sudo add-apt-repository ppa:kelebek333/kablosuz sudo apt update && sudo apt install rtl8188fu-dkms sudo reboot
I have also deactivated security boot in BIOS.
Thanks for any support!
znt
2
Ok now it works
edit: did the follwing, suggedsted by MIchel in other thread:
In terminal write: sudo apt-get install mokutil && mokutil --sb-state
If secure boot is enabled disable it in bios and run this command.
In terminal write: sudo apt-get install rtl8821ce-dkms
system
Closed
3
