I've installed zorin lite on an old pc. It has no in-built wifi. So I bought a dongle but to my disappointment I didn't find drivers for it. Now, how do I setup wifi on my pc. Is there a GUI based wifi install?
I think my wifi dongle is Ralink mt7601.
It doesn't work. All Wifi Adapters or Dongles is not supported by Zorin OS
Do a websearch for "mt7601 Ubuntu 18.04" and see what comes up. I am assuming you are on Z15.3 not Z16Beta. One will likely be:
Read right through the comments. It may or may not give you the solution, but may point you in the right direction.
