so this afternoon i turned on my laptop.. and it seems the that my wifi icon is missing.
i did restart it twice, and i checked software updater for any updates, and restarted after the updates again and still nothing, although i typed in wifi in the terminal and it says its on, and working. so i dont know, i tried adding new items to the panel, because maybe i could just re-add the wifi icon or something but i cant find anything, any help?
First thing to try:
Zorin>Settings>Wifi
Is it turned off there.
Does your pc have a switch or keyboard function to turn off WiFi. Check that.
hello, no, like i said my wifi is on and working (according to the terminal) and i am able to access browser fine and all, but its just that the wifi icon is missing in the panel.
there is nothing wrong with the wifi itself, nor do i have a function to turn off wifi on my keyboard that i know of.
right click on the panel(taskbar) and choice panel=>Add new item=>choice status Try plugin and click add
Thank you for your help, this worked.
