Hello all,
I recently got a used HP Pavillon x2 detachable.
I nuked windows and installed Zorin OS 16.1 lite.
The system works like a charm, but with one serious issue
My Wifi is not working correctly
I see all the SSID but cant connect.
I did lshw -c Network
<pre> *-network:0 Beschreibung: Kabellose Verbindung Physische ID: 3 Logischer Name: wlan0 Seriennummer: 80:a5:89:12:24:79 Fähigkeiten: ethernet physical wireless Konfiguration: broadcast=yes driver=rtl8723bs driverversion=5.13.0-39-generic multicast=yes wireless=unassociated *-network:1 Beschreibung: Ethernet interface Physische ID: 4 Bus-Informationen: usb@1:2 Logischer Name: enx46da300ba868 Seriennummer: 46:da:30:0b:a8:68 Fähigkeiten: ethernet physical Konfiguration: broadcast=yes driver=ipheth driverversion=5.13.0-39-generic ip=172.20.10.2 link=yes multicast=ye </pre>
IS it something with the driver?
I stopped the Networkmanager and restartet it. The driver seems to be installed, otherwise i would not see the Hardware, right?
If someone could have a look and give me some tipps, that would be great
Thank you in advance
can you run the hardware probe for us and share the results?
here you go
[img width=300]{YOUR COMPUTER IMAGE URL}[/img]
[b]Host: Hewlett-Packard Pavilion x2 Detachable 2015 - hand held with Zorin 16 (exported from [url=https://linux-hardware.org/?probe=fdcebf57ee]Linux-Hardware.org[/url])[/b]
[url=https://linux-hardware.org/?probe=fdcebf57ee]PROBE ID[/url]
{TELL THE STORY ABOUT YOUR COMPUTER HERE}
Devices on the board are the following:
[table][tr][td][b]DEVICE[/b][/td]
[td][b]STATUS[/b][/td]
[td][b]COMMENT[/b][/td]
[/tr]
[tr][td]BUS: PCI
CLASS: 03-00
VENDOR: Intel Corporation
DEVICE: [b]Atom Processor Z36xxx/Z37xxx Series Graphics & Display[/b]
TYPE: graphics card
DRIVER: i915
[/td]
[td]
Works
[/td]
[td]
[/td]
[/tr]
[tr][td]BUS: PCI
CLASS: 06-00
DEVICE: [b]Atom Processor Z36xxx/Z37xxx Series SoC Transaction Register[/b]
TYPE: bridge
DRIVER: iosf_mbi_pci
[/td]
[td]
Detected
[/td]
[td]
[/td]
[/tr]
[tr][td]BUS: PCI
CLASS: 06-01
DEVICE: [b]Atom Processor Z36xxx/Z37xxx Series Power Control Unit[/b]
TYPE: bridge
DRIVER: lpc_ich
[/td]
[td]
Detected
[/td]
[td]
[/td]
[/tr]
[tr][td]BUS: PCI
CLASS: 10-80
DEVICE: [b]Atom Processor Z36xxx/Z37xxx Series Trusted Execution Engine[/b]
TYPE: encryption controller
DRIVER: mei_txe
[/td]
[td]
Detected
[/td]
[td]
[/td]
[/tr]
[tr][td]BUS: PCI
CLASS: 0c-03-30
DEVICE: [b]Atom Processor Z36xxx/Z37xxx, Celeron N2000 Series USB xHCI[/b]
TYPE: usb controller
DRIVER: xhci_pci
[/td]
[td]
Works
[/td]
[td]
[/td]
[/tr]
[tr][td]BUS: USB
CLASS: 06-01-01
VENDOR: Apple, Inc.
DEVICE: [b]iPhone 5/5C/5S/6/SE[/b]
TYPE: network
DRIVER: ipheth, apple_mfi_fastcha...
[/td]
[td]
Works
[/td]
[td]
[/td]
[/tr]
[tr][td]BUS: USB
CLASS: 09-00-01
VENDOR: Genesys Logic, Inc.
DEVICE: [b]Hub[/b]
TYPE: hub
DRIVER: hub
[/td]
[td]
Detected
[/td]
[td]
[/td]
[/tr]
[tr][td]BUS: USB
CLASS: 09-00-00
VENDOR: Linux Foundation
DEVICE: [b]2.0 root hub[/b]
TYPE: hub
DRIVER: hub
[/td]
[td]
Works
[/td]
[td]
[/td]
[/tr]
[tr][td]BUS: USB
CLASS: 09-00-00
DEVICE: [b]3.0 root hub[/b]
TYPE: hub
DRIVER: hub
[/td]
[td]
Detected
[/td]
[td]
[/td]
[/tr]
[tr][td]BUS: USB
CLASS: 03-01-01
VENDOR: Elan Microelectronics Corp.
DEVICE: [b]USB Mouse[/b]
TYPE: mouse
DRIVER: usbhid
[/td]
[td]
Detected
[/td]
[td]
[/td]
[/tr]
[tr][td]BUS: EISA
VENDOR:
DEVICE: [b]LCD Monitor 1280x800[/b]
TYPE: monitor
DRIVER: -
[/td]
[td]
Works
[/td]
[td]
[/td]
[/tr]
[tr][td]BUS: SYS
VENDOR:
DEVICE: [b]Battery Li-ion 22 Wh[/b]
TYPE: battery
DRIVER: -
[/td]
[td]
Works
[/td]
[td]
[/td]
[/tr]
[tr][td]BUS: SYS
VENDOR: Insyde
DEVICE: [b]BIOS F.11 08/20/2015[/b]
TYPE: bios
DRIVER: -
[/td]
[td]
Works
[/td]
[td]
[/td]
[/tr]
[tr][td]BUS: SYS
VENDOR: Intel
DEVICE: [b]Atom CPU Z3736F @ 1.33GHz[/b]
TYPE: cpu
DRIVER: -
[/td]
[td]
Works
[/td]
[td]
[/td]
[/tr]
[tr][td]BUS: SYS
VENDOR: HYNIX
DEVICE: [b]RAM H5TC4G63AFR_PBA 2048MB SODIMM DDR3 1333MT/s[/b]
TYPE: memory
DRIVER: -
[/td]
[td]
Works
[/td]
[td]
[/td]
[/tr]
[tr][td]BUS: SYS
VENDOR: Hewlett-Packard
DEVICE: [b]Motherboard 815D 26.0E[/b]
TYPE: motherboard
DRIVER: -
[/td]
[td]
Works
[/td]
[td]
[/td]
[/tr]
[tr][td]BUS: INT
VENDOR:
DEVICE: [b]MMC Controller[/b]
TYPE: mmc controller
DRIVER: mmcblk
[/td]
[td]
Detected
[/td]
[td]
[/td]
[/tr]
[tr][td]BUS: INT
VENDOR:
DEVICE: [b]SDIO Controller 0[/b]
DRIVER: -
[/td]
[td]
Works
[/td]
[td]
[/td]
[/tr]
[tr][td]BUS: PS/2
VENDOR:
DEVICE: [b]SYNA7508:00 06CB:1497[/b]
TYPE: mouse
DRIVER: -
[/td]
[td]
Detected
[/td]
[td]
[/td]
[/tr]
[tr][td]BUS: PS/2
VENDOR:
DEVICE: [b]SYNA7508:00 06CB:1497 Stylus[/b]
TYPE: mouse
DRIVER: -
[/td]
[td]
Detected
[/td]
[td]
[/td]
[/tr]
[tr][td]BUS: SDIO
CLASS: 07
VENDOR:
DEVICE: [b][/b]
TYPE: network
DRIVER: rtl8723bs
[/td]
[td]
Detected
[/td]
[td]
[/td]
[/tr]
[tr][td]BUS: SDIO
VENDOR:
DEVICE: [b]WLAN controller[/b]
TYPE: network
DRIVER: r8723bs
[/td]
[td]
Works
[/td]
[td]
[/td]
[/tr]
[tr][td]BUS: MMC
VENDOR: SK hynix
DEVICE: [b]HBG4e 32GB[/b]
TYPE: disk
DRIVER: sdhci_acpi, mmcblk
[/td]
[td]
Detected
[/td]
[td]
[/td]
[/tr]
[/table]
@ExtremeShark , can you please help us out and post the output for
sudo lshw -c network
That driver is included in the kernel - but may need to be patched. Please review this post here:
https://forums.linuxmint.com/viewtopic.php?p=1911297#p1911297
Wow, that is kind of complicated. It would be great when someone could help me with that. I do not know where to find these files
Yes, it is.
In fact, I would actually try the Liquorix or Tuxinvader kernel before trying to run headlong down that rabbit hole...
system
Closed
July 17, 2022, 6:27pm
9
