Hey . I bought an asus vivobook go and i install zorin os 18 core . After installation bluetooth and WiFi not detected at all . Set Up Wi-Fi - Zorin Help I Try all this things but still not work . From bios all looks good . Secure mode off and all updates are up . Any idea ??
You could take a Look at this:
and this:
i did all that. So the final resolution is to take a wifi adaptor?
When You type in the Terminal sudo apt install linux-firmware what Output do You get?
[sudo] password for sotiris:
Sorry, try again.
Reading package lists... Done
linux-firmware is already the newest version (20240318.git3b128b60-0ubuntu2.21).
linux-firmware set to manually installed.
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
I searched and found this summary:
"In summary, there is no official Linux driver for the ASUS Vivobook Go 15's wireless hardware as of November 2025, and users must rely on external USB Wi-Fi adapters or hardware replacement to achieve wireless connectivity."
You could try a newer kernel but suspect you would still not have wifi. I would advise purchasing a suitable dongle.
