Wifi not found
New install 16.3 lite. internal Wifi not working and currently using a usb wifi. Ran upgrade zorin os. Still no wifi
toshiba@toshiba-Satellite-C55t-C:~$ [quote="Aravisian, post:1, topic:5484"]
[quote=Aravisian, post:1, topic:5484]: command not found
toshiba@toshiba-Satellite-C55t-C:~$ sudo lshw -C network
[sudo] password for toshiba:
Sorry, try again.
  *-network UNCLAIMED
       description: Network controller
       product: BCM43142 802.11b/g/n
       vendor: Broadcom Inc. and subsidiaries
       physical id: 0
       bus info: pci@0000:07:00.0
       version: 01
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list
       configuration: latency=0
       resources: memory:b3200000-b3207fff
  *-network
       product: RTL810xE PCI Express Fast Ethernet controller
       physical id: 0
       bus info: pci@0000:08:00.0
       logical name: enp8s0
       version: 07
       serial: 2c:60:0c:c5:89:1f
       capacity: 100Mbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix vpd bus_master cap_list rom ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=5.15.0-107-generic firmware=rtl8106e-1_0.0.1 06/29/12 latency=0 link=no multicast=yes port=twisted pair
       resources: irq:19 ioport:3000(size=256) memory:b3004000-b3004fff memory:b3000000-b3003fff memory:90100000-9010ffff
  *-network
       physical id: 3
       bus info: usb@2:3
       logical name: wlx0013ef8023fb
       serial: 00:13:ef:80:23:fb
       capabilities: ethernet physical wireless
       configuration: broadcast=yes driver=rtl8xxxu driverversion=5.15.0-107-generic firmware=N/A ip=192.168.1.85 link=yes multicast=yes wireless=IEEE 802.11
toshiba@toshiba-Satellite-C55t-C:~$ lspci
00:00.0 Host bridge: Intel Corporation Broadwell-U Host Bridge -OPI (rev 09)
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 5500 (rev 09)
00:03.0 Audio device: Intel Corporation Broadwell-U Audio Controller (rev 09)
00:14.0 USB controller: Intel Corporation Wildcat Point-LP USB xHCI Controller (rev 03)
00:16.0 Communication controller: Intel Corporation Wildcat Point-LP MEI Controller #1 (rev 03)
00:1b.0 Audio device: Intel Corporation Wildcat Point-LP High Definition Audio Controller (rev 03)
00:1c.0 PCI bridge: Intel Corporation Wildcat Point-LP PCI Express Root Port #1 (rev e3)
00:1c.2 PCI bridge: Intel Corporation Wildcat Point-LP PCI Express Root Port #3 (rev e3)
00:1c.3 PCI bridge: Intel Corporation Wildcat Point-LP PCI Express Root Port #4 (rev e3)
00:1c.5 PCI bridge: Intel Corporation Wildcat Point-LP PCI Express Root Port #6 (rev e3)
00:1d.0 USB controller: Intel Corporation Wildcat Point-LP USB EHCI Controller (rev 03)
00:1f.0 ISA bridge: Intel Corporation Wildcat Point-LP LPC Controller (rev 03)
00:1f.2 SATA controller: Intel Corporation Wildcat Point-LP SATA Controller [AHCI Mode] (rev 03)
00:1f.3 SMBus: Intel Corporation Wildcat Point-LP SMBus Controller (rev 03)
07:00.0 Network controller: Broadcom Inc. and subsidiaries BCM43142 802.11b/g/n (rev 01)
08:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL810xE PCI Express Fast Ethernet controller (rev 07)
09:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS5229 PCI Express Card Reader (rev 01)
toshiba@toshiba-Satellite-C55t-C:~$ screenfetch
................... toshiba@toshiba-Satellite-C55t-C
:ooooooooooooooooooo/ OS: Zorin OS 16
/ooooooooooooooooooooo+ Kernel: x86_64 Linux 5.15.0-107-generic
'''''''''''''''''''''''' Uptime: 56m
Packages: 1668
.++++++++++++++++++/. :++- Shell: bash 5.0.17
-oooooooooooooooo/- :+ooooo: Resolution: 1366x768
:oooooooooooooo/- :+ooooooooo: DE: Xfce
.oooooooooooo+- :+ooooooooooooo- WM: Xfwm4
-oooooooo/- -+ooooooooooooooo: WM Theme: ZorinBlue-Light
.oooo+- -+ooooooooooooooooo- GTK Theme: ZorinBlue-Light [GTK2]
.-- .-------------------. Icon Theme: ZorinBlue-Light
Font: Inter 10
.//////////////////////- Disk: 97G / 919G (12%)
:oooooooooooooooooooo/ CPU: Intel Core i3-5020U @ 4x 2.1GHz [47.0°C]
:oooooooooooooooooo: GPU: Mesa Intel(R) HD Graphics 5500 (BDW GT2)
'''''''''''''''''' RAM: 1848MiB / 5841MiB
Hi and welcome to the forum.
Have you tried installing drivers for your hardware?
Also seen one item that asks if (BIOS) "Secure Boot" is disabled.
My websearch using "Broadcom BCM43142 unclaimed Ubuntu 20.04" found this:
(Note Z16.x is based on Ubuntu 20.04)
See this: wireless - BCM43142 WiFi adapter doesn't work on Ubuntu 20.04 - Ask Ubuntu
Also may be of help:
networking - How do I fix network UNCLAIMED wifi failure? - Ask Ubuntu.
Thanks! I downloaded then installed broadcom-sta-dkms_6.30.223.271-12ubuntu0.1_all.deb which i think i found in the 2nd link you provided. Im not sure which now.... they were confusing with so many links!
Thanks for the help!!!
https://packages.ubuntu.com/noble/broadcom-sta-dkms
