WiFi slow/ dropping
Hi, I'm new to Zorin OS 18 Core. I installed it on a new computer. I noticed a few things weren't going so well with the internet/WiFi. I haven't tested anything with a wired connection, but I could, if you would recommend it.
There have been several times when my web browser says, "Hmm. We’re having trouble finding that site." I have to keep trying again a few times. Then it loads the page. Sometimes Zorin OS says I am disconnected from WiFi internet for a short time. Then it goes away. I'm getting of oddities on running Youtube videos. About 99% of the time it's fine, but I seem to have some hiccups in Youtube videos, that is, the audio sounds a bit odd or garbled for less than one second. That's pretty bad with running a video at 360p. Files like 200kb PNG pictures load slower than on Windows. My internet speed test is getting values way lower than my Windows laptop using the same router. I have checked the "Software&Updates" program, with, "Additional Drivers." It says, "no additional drivers available." I wonder if it has to do with something pretty important within the software/hardware or maybe DNS.
It would be good to have that as a Comparision to see if there are the same Issues.
Some Questions:
  • If Windows is still installed: Is Fast Start-Up in Windows disabled?
  • Does Your System run in Wayland or X11? You can check that with the Terminal Command echo $XDG_SESSION_TYPE
  • What Kernel is in Use? You can check that with uname -r in Terminal
  • Could You post the Output of the Commands sudo lshw -C network and rfkill list please?
No dual-booting with Windows.
SecureBoot disabled
kernel: 6.17.0-14-generic
Wayland
sudo lshw - C network reveals:
*-network
       product: RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet Controller
       physical id: 0
       bus info: pci@0000:02:00.0
       logical name: enp2s0
       version: 15
       serial: a8:2b:dd:4c:b9:df
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=6.17.0-14-generic firmware=rtl8168h-2_0.0.2 02/26/15 latency=0 link=no multicast=yes port=twisted pair
       resources: irq:49 ioport:3000(size=256) memory:80804000-80804fff memory:80800000-80803fff
  *-network
       product: RTL8852CE PCIe 802.11ax Wireless Network Controller
       physical id: 0
       bus info: pci@0000:03:00.0
       logical name: wlp3s0
       version: 01
       serial: 14:b5:cd:4d:29:a7
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
       configuration: broadcast=yes driver=rtw89_8852ce driverversion=6.17.0-14-generic firmware=N/A ip=192.168.0.109 latency=0 link=yes multicast=yes wireless=IEEE 802.11
       resources: irq:66 ioport:2000(size=256) memory:80700000-807fffff
rfkill list reveals:
0: tpacpi_bluetooth_sw: Bluetooth
	Soft blocked: no
	Hard blocked: no
2: phy0: Wireless LAN
	Soft blocked: no
	Hard blocked: no
5: hci0: Bluetooth
	Soft blocked: no
	Hard blocked: no
Have you disabled powersave? The newer wifi6 driver is known to be a bit unstable with powersave
sudo nano /etc/NetworkManager/conf.d/wifi-powersave.conf
Change value to 2
[connection]
wifi.powersave = 2
Tap ctl+o to overwrite, enter to save as current configuration, then ctl+x to exit the editor.
The change will take effect on reboot or network service restart.
Go to Zorin OS settings, then "Software & Updates," and click on "Network" and then "Network Manager." Click on the "Reset" button. This will reset your network manager to its default state.
Maybe try it with the older Kernel. On the GRUB Menu on Start-Up choose ''Advanced Options'' and there take the Option with the 6.14 Kernel and check if it works again.
Could be a Point, too. You could try it with switching to X11/Xorg. To do that, go to the Login Screen. click on Your Profile so that the Password Field appears. When it is appeared, You should see a Gear Icon in the bottom right Corner. Click on it and choose the Option ''Zorin Desktop on Xorg'' and then log in.
Good news. I tried this first, since it was the first reply. The file that you said to change was really under the file name "default-wifi-powersave-on.conf" I changed it as you said. The network speed test is much better. I have feeling this solved my problem!
I am detecting a new, perhaps unrelated, problem. I was watching a Youtube video, and I loaded a web page with like 800kb worth of info/picture files. The sound on the Youtube video gets garbled for a second. This happens even more when I loaded something with many more megabytes. I really didn't get this on any computer I've used. It feels like a problem that occurs when the CPU is maxing out. But that was the old days. This CPU is not maxing out.
What about Hardware Acceleration in the browser? Have you tried disabling it?
The performance setting/hardware acceleration setting on Firefox doesn't seem to change the problem. I am starting to think this is some type of a software problem. I'm not sure if there is a better way to post this in a subforum/thread about software.
This!
I just went through this, buffering videos slow websites. Slow speeds on speedtest.
I set it to 2 and my LAN came to life. I have nice hardware "680 Mb/s (5.8 GHz)" atm, and now it's snappy like it should be.
Could this be a problem with bluetooth headphones? It is sound-related.
I think just my bluetooth headphones are getting the problem with the sound. Maybe some sort of software problem is sending a bad signal to the bluetooth headphones just when I try to use more internet downloading (and/or CPU?)
Sometimes there can be interferences between bluetooth and wlan. You could test if it solves your problem when you switch to 5 GHz in your wlan router settings.
I think I've been having success with sudo systemctl restart bluetooth and/or restarting it with the settings controls
The problems with the bluetooth keep happening. If I turn on/turn off bluetooth, it doesn't do very much. I'm attempting to change to 5GHz on my router. There may be something else going on. I'm really not sure that Linux is the problem. I'd love to fix it. My headphones always work correctly with Windows 11 on my old laptop.
I downloaded Bluetooth Manager (Blueman-manager 2.3.5) and... it didn't seem to change a whole lot. I had the bluetooth off for a while. I turned it back on, and things seem to be normal again. Blueman-manager seems to do a good job of recognizing when I turn on the headphones and connecting. But I don't know exactly what's been happening.
Sometimes my bluetooth headphones stop getting data from my computer. I just disconnect and reconnect, then. I'm not sure if I can track down a solution, based on such little information.
