I think Mega is free up to 30GB.
0hk, thats a generus am0und 0f free space, let me give it a try
Linux installer:
https://mega.nz/sync
Select Ubuntu 18.04 32bit (Zorin is based on Ubuntu)
br000,,,,,wtf h0w did y0u knw thats where i was stuck.... lmfa... i swear i thught abut asking but than i was like, ■■■■ i c0uld prbably find this inf smwhere, and i just finished installing it, and saw yur message
What do you see when you open "additional driver"?
I think you should be able to find it in the control panel of XFCE.
i dnt cmpletely understand the questin, what is this regarding? the wifi card drivers?
i checked under settings- additinal drivers- it was searching fr a bit, n0 additional drivers are available
Ah, OK. Thanks.
That is what I was asking.
Can you give me a make/model of your laptop?
hi, its nt a laptp. its a stick pc, len0v0 ideacenter stick pc 300
I think this is what you have:
https://www.cnet.com/products/ideacentre-stick-300/
It has one of those WiFi and Bluetooth combo cards.
I have a similar stick computer (Intel Compute Stick).
I have to disable Bluetooth on it due to its interference to WiFi.
If you are not using Bluetooth function, you could disable it in BIOS and see if it makes any difference.
There are a lot of separate questions in this thread:
Cloud Storage, Mapping Keys and Wifi...
ef4827, can you please open a new thread for each question? In this way, it helps stay organized and prevents multi issues from confusing one thread. It also allows for the solution to be found by other users.
I believe that the Keyboard and 0 for o problem should be address as the highest priority as terminal commands may be tricky if you cannot enter them.
On wifi:
I am still not sure what device you are using. Can you please post the terminal output of
lshw -C network
And I am having a hard time to decipher the extortion notes ![]()
give me the wifi an n0b0dy gets hurt
sorry about the late reply, i just got home from work. this is what i get
z@Z-PC:~$ lshw -C network
WARNING: you should run this program as super-user.
-network
physical id: 3
logical name: wlan0
serial: 80:a5:89:20:71:4b
capabilities: ethernet physical wireless
configuration: broadcast=yes driver=rtl8723bs ip=*********
multicast=yes wireless=IEEE 802.11bg
WARNING: output may be incomplete or inaccurate, you should run this program as super-user.
Sooooooooooooooooooooo....what's up man. how do you like me new keyboard with a functional o key.
You replaced your keyboard?
Glad to here that it is working.
BTW, you got my gender wrong ![]()
