Hello, I'm having problems with my Intel (i7-11700k CPU) onboard Wi-Fi. It's a third slower (150 Zorin/450 Win 11 Mbps) than under Windows 11.
Intel i7-11700k
32GB RAM
Nvidia 3070
Did You take a Look in the ''Additional Drivers'' tab if there is a Driver for Your Wifi offered?
Another Thing: Does Your System run in wayland or X11/Xorg? You can check that in Settings>About.
What is your motherboard make and model? Thanks.
Welcome to Zorin Forum!
I'm sure this is extremely basic, but have you finished updating the OS fully?
I think this should work too. I'm not able to recollect, but there was a command to get updates for the additional packages, maybe this app is based on this.
