And will they all work out of the box?
Or will I have to tinker with my distros?
If so, will it be easy?
Note: I'm using the lite version of Zorin Os.
I think I once read that e-cores would only work with Windows?
But I'm guessing the Ubuntu community will fix this?
I haven't found a clear, "yes, every single Linux/Ubuntu distros can use all e-cores p-cores threads out of the box."
I use the 3d animation software Blender almost everyday.
And Obs.
Might play more games again.
Thanks.
What I found on Google:
This forum poster wasn't getting all the cores at first, but eventually got it to work:
Ubuntu 22.04 support for 12th gen Intel CPU - Ask Ubuntu
This post looks like all their p-cores and e-cores and threads are online:
x86 64 - How to detect E-cores and P-cores in Linux alder lake system? - Stack Overflow
Zorin 16.2 uses the same kernel as Ubuntu 22.04 (5.15), so it should work with 12th gen Intel processors and recognise your cores. To be sure, run a live boot from a USB.
Thanks. That gives me hope.
You said 12th gen but 13th gen. Should all the threads work for 13th gen, too?
I haven't confirmed, but again, you might want to give it a try if you have a 13th gen Intel powered computer.
Update: Intel 13th gen is not supported until kernel 6.0. You may want to turn to other OSes that support this kernel (such as Ubuntu 23.04 and Pop OS 22.04) until Zorin 17 comes out.
The short answer to your question is "no." The longer answer is "yes." And the reason for the discrepancy is: It's complicated.
For all intents and purposes, the simple "no" would be the most accurate.
And as far as "why" goes, it is because the system will actually run leaner nor using all p-cores and all e-cores except for special demand.
If you want to ensure that this is the case and that all are capable of being used, then as @Turtle11 pointed out, you will need the higher kernel. You can install it with:
sudo add-apt-repository ppa:tuxinvader/lts-mainline
sudo apt update
sudo apt install linux-generic-6.02
Sorry, but I don't understand this sentence.
Wow, interesting typo... Corrected:
You will not gain improvement from running all hyperthreads. The best analogy I can think of is a Lamborghini.
You take this supercar out on the roads and due to a speed limit, you cannot use all the available horsepower.
