Windoze drive scans after linux usage
Is there a workaround so that windoze doesn't have to rescan the drive on a login after using linux in dual boot mode?
Hi and welcome to Zorin forum.
Is it Windows Explorer rescanning the drive after it has been used by Linux or a Scan and Fix prompt? That question may be better asked on a Windows forum.
https://www.sevenforums.com/tutorials/227778-scan-fix-removable-disk-prompt-disable-windows.html
