In this case, I doubt reinstalling Zorin OS will change this.
However, there are some things you can try just to be sure:
Open Software & Updates
and read the sources list carefully and ensure that you Do Not have any Wine Repositories added that should not be there (Like Groovy or Impish). Ensure you have ONLY the Focal Wine Repository. Remove any others like Groovy or Impish if they are present.
Change your /etc/apt/sources.list
to Main Server Manually.
I would go with GUI on this, just to make your life easier.
sudo -i
Because you use Zorin OS Pro Lite:
thunar
(Pro or Core users should enter in nautilus
instead.)
Now, tap the up arrow key on the toolbar two times to got to the top of the tree in root. Then double click /etc, then /apt and then right click the sources.list
file and open it with your Text Editor of choice.
Ignore any line with a (#) at the front.
Look for a line like deb http://archive.ubuntu.com/ubuntu focal main restricted
that has a Regional Server noting it and remove that two letter regional indicator to make the line look exactly like the one I pasted above.
Repeat for:
deb http://us.archive.ubuntu.com/ubuntu/ focal-updates main restricted
deb http://archive.ubuntu.com/ubuntu focal universe
deb http://us.archive.ubuntu.com/ubuntu/ focal-updates universe
deb http://archive.ubuntu.com/ubuntu focal multiverse
deb http://us.archive.ubuntu.com/ubuntu/ focal-updates multiverse
deb http://us.archive.ubuntu.com/ubuntu/ focal-backports main restricted universe multiverse
deb http://security.ubuntu.com/ubuntu focal-security main restricted
deb http://security.ubuntu.com/ubuntu focal-security universe
deb http://security.ubuntu.com/ubuntu focal-security multiverse
deb http://archive.ubuntu.com/ubuntu focal-updates restricted multiverse universe main
deb http://archive.ubuntu.com/ubuntu focal-backports restricted multiverse universe main
Once done, Save the file
Close it out, close out Thunar.
In the terminal, run sudo apt update && sudo apt upgrade
Try installing Wine...
