Yeah apt was fixed and functioning perfectly
So current standing is- Zorin OS 15.3 Education functional - midway through installing Wine which is throwing crazy dependency errors... Correct?
Yes absolutely. All other tasks are functional, except the wine and sometimes libc6, like while installing qt5 or stuff like that for playing video games, it shows higher libc6 is required, but the default for zorin is 2.28(hope I am correct) so those can't be installed as many things depends on version 2.28.
In this case, I would like to back up a bit and start over- partly due to Artyom Zorins post here:
I think opening Software & Updates app and removing any WineHQ repositories first... Then removing ~/.wine directory manually...
Then run
sudo apt remove --purge wine*
Get rid of anything that may be bungling up the pipes.
Then test if the package zorin-windows-app-support will now get you sorted out. This is not a pedestal action; I have learned in my time using Zorin OS that if an existing method or app exists, often ZorinGroup finds a way to do it thoroughly and better. So, fingers crossed...:
sudo apt install -y zorin-windows-app-support
That did it!! Thanks a lot
We needed a "win"...
Thanks to ZorinGroup for correcting packages.
A post was split to a new topic: Having trouble installing Wine/ App-support
That worked a treat! Thanks very much. Oct 2023 Zorin 16
