Wine system tray problem
I had installed wine to use wechat but wine system tray came out when I log in.
I tried to installed gnome-shell-extension-top-icons-plus to fix the problem,but the installation failed.
error:Gnome-shell-extension-top-icons-plus: depends on: gnome-shell (<3.37), but 3.38.4-1 ubuntu3+zorin1 is installed
The error cannot be corrected because you require some software packages to maintain the status quo, which is that they break the dependency relationship between software packages.
I found the way to solve the problem myself
1 Install the chrome browser
2 install the GNOME Shell integration
3 install chrome-gnome-shell in terminal
4 enable top icons fix in TopIconsFix - GNOME Shell Extensions
5 finish!
hi. I tried this solution but I'm getting the error that no native host connector is detected.
