inxi -Fx
System: Host: alex-linxpc Kernel: 5.4.0-45-generic x86_64 bits: 64 gcc: 7.5.0
Desktop: Gnome 3.30.2 (Gtk 3.22.30-1ubuntu4) Distro: Zorin OS 15.3
Machine: Device: desktop System: ASUS product: N/A serial: N/A
Mobo: ASUSTeK model: PRIME B560M-A v: Rev 1.xx serial: N/A
UEFI: American Megatrends v: 0403 date: 01/26/2021
Battery hidpp__0: charge: N/A condition: NA/NA Wh
model: Logitech M720 Triathlon Multi-Device Mouse status: Discharging
hidpp__1: charge: N/A condition: NA/NA Wh
model: Logitech K850 Performance Wireless Keyboard status: Discharging
CPU: 8 core 11th Gen Intel Core i7-11700F (-MT-MCP-) arch: N/A cache: 16384 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 39936
clock speeds: max: 4800 MHz 1: 800 MHz 2: 800 MHz 3: 800 MHz 4: 800 MHz 5: 800 MHz 6: 862 MHz
7: 800 MHz 8: 800 MHz 9: 800 MHz 10: 800 MHz 11: 800 MHz 12: 800 MHz 13: 1326 MHz 14: 1211 MHz
15: 1363 MHz 16: 888 MHz
Graphics: Card: NVIDIA GP107 [GeForce GTX 1050 Ti] bus-ID: 01:00.0
Display Server: x11 (X.Org 1.20.8 ) drivers: nvidia (unloaded: modesetting,fbdev,vesa,nouveau)
Resolution: 1920x1080@60.00hz, 1920x1080@60.00hz
OpenGL: renderer: GeForce GTX 1050 Ti/PCIe/SSE2 version: 4.6.0 NVIDIA 450.66 Direct Render: Yes
Audio: Card-1 NVIDIA GP107GL High Definition Audio Controller driver: snd_hda_intel bus-ID: 01:00.1
Card-2 Intel Device 43c8 driver: snd_hda_intel bus-ID: 00:1f.3
Card-3 Microsoft LifeChat LX-3000 Headset driver: USB Audio usb-ID: 001-003
Sound: Advanced Linux Sound Architecture v: k5.4.0-45-generic
Network: Card: Intel Device 15fa bus-ID: 00:1f.6
IF: N/A state: N/A speed: N/A duplex: N/A mac: N/A
Drives: HDD Total Size: 2512.5GB (24.2% used)
ID-1: /dev/nvme0n1 model: ADATA_SX8200PNP size: 512.1GB
ID-2: /dev/sda model: TOSHIBA_HDWD110 size: 1000.2GB temp: 34C
ID-3: USB /dev/sdb model: HD103SI size: 1000.2GB temp: 0C
Partition: ID-1: / size: 362G used: 13G (4%) fs: ext4 dev: /dev/sdb6
RAID: No RAID devices: /proc/mdstat, md_mod kernel module present
Sensors: System Temperatures: cpu: 33.0C mobo: N/A gpu: 1.0:33C
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 371 Uptime: 6 min Memory: 1983.4/15871.4MB Init: systemd runlevel: 5 Gcc sys: 7.5.0
Client: Shell (bash 4.4.201) inxi: 2.3.56
This Network adapter gained support in kernel 5.5 and higher...
Upgrading your kernel may do the trick...
To install:
Download each .deb file and transfer to a USB.
Plug the USB into your computer without networking and move all three files to your home Downloads folder.
In your terminal, change directory to downloads
cd ~/Downloads
Then enter in:
dpkg -i *.deb
The * sign should cause all three .deb packages to install in order in one command.
Double-post: Please see above for Kernel Pointers.
Afterthought: Your hardware would be well supported in Zorin 16; though Zorin OS 16 Ultimate is still in development. Even so, it may be worth testing for you to try out since you are on a fresh clean install, anyway...
https://sourceforge.net/projects/zorin-os/files/16/beta/Zorin-OS-16-Core-Beta-64-bit.iso/download?use_mirror=phoenixnap
IF that works well and properly, let's message the ZorinGroup to see about refunding your purchase of Zorin OS 15.3 Ultimate that you may choose to either hold for the Z16 Ultimate Release or donate to the team, instead:
Hello!I also meet a similar question in wired connection.Is the problem solved?
hello
i've the same problem of not being able to connect the wired internet
thanks and love
Hi and welcome to the forum
Can you post the output of this command?
lspci
hello!
YES
This is your Ethernet module:
Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 0c)
I wonder if you need a driver for this.
Lemme look around.
[edit]
This should be the right driver:
https://ubuntu.pkgs.org/20.04/ubuntu-universe-amd64/r8168-dkms_8.048.00-1_all.deb.html
With r8168-dkms everything is working fine!
tnx
but how to install?
Download .deb file.
In file manager you can double click on it to install.
[edit]
Actually, this one is easier.
- Update the package index:
# sudo apt-get update
- Install r8168-dkms deb package:
# sudo apt-get install r8168-dkms
i'm not sure how to download it with the browser
can i do sudo apt-get install r8168-dkms too?
tnx
i saw your eddit
so it actually didn't work.... unfortunately....
i even rebooted..
i want to mention that i could only do this:
because i don't know if the .deb can be downloaded
anyhow it didn't worked as i mentioned
edit:
when i'm trying to determine the motherboard model i get:
Manufacturer: Gigabyte Technology Co., Ltd.
Product Name: To be filled by O.E.M.
Version: To be filled by O.E.M.
Gigabyte Motherboards are notorious.
https://bugs.launchpad.net/ubuntu/+source/linux-signed/+bug/1876593
You most likely need a BIOS update on your motherboard.
The drivers for your net card are included in the Linux kernel and should require no configuration, normally.
https://www.pcgamesn.com/bios-update
- Download the corresponding BIOS update for your motherboard from the Gigabyte website.
- Upon restarting your PC, mash the DEL key to kingdom come. You can also jump straight to Q-Flash, Gigabyte’s BIOS flash utility, directly by pressing the END key during startup with most Gigabyte boards.
- Navigate to Q-Flash – you may need to press the ALT key to bring up the Q-Flash shortcut from the BIOS menu.
- Select Update BIOS
- Select the extracted BIOS from your storage drive
- Press ENTER and agree to update your BIOS
- Be patient and let your PC do its thing.
- Re-apply settings.
thank you
if i want to know the motherboard model i need to open the computer and look closely to find it?
Since I assembled this Gigabyte machine myself I took a note of silkscreen printed on it to get a revision number beforehand. For my m/b, rev.1 and rev.2 require a different BIOS, drivers, etc.
It it were store bought machine you might want to open the case and read the silkscreen to be sure of the model number (and revision, if any).
Your m/b manual should say where this silkscreen locates on m/b.
