I upgraded to Zorin 16 Beta. My wifi works but it slow and my wired internet does not work at all. I have tested on another computer and there is no issue with connection on other computers.
lshw -c network
*-network
product: Wi-Fi 6 AX200
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:03:00.0
logical name: wlp3s0
version: 1a
serial: 60:f2:62:51:0e:05
width: 64 bits
clock: 33MHz
capabilities: bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=iwlwifi driverversion=5.8.0-55-generic firmware=55.d9698065.0 cc-a0-55.ucode ip=192.168.0.24 latency=0 link=yes multicast=yes wireless=IEEE 802.11
resources: irq:29 memory:f6600000-f6603fff
*-network UNCLAIMED
description: Ethernet controller
product: RTL8125 2.5GbE Controller
physical id: 0
bus info: pci@0000:04:00.0
version: 04
width: 64 bits
clock: 33MHz
capabilities: cap_list
configuration: latency=0
resources: ioport:f000(size=256) memory:f6500000-f650ffff memory:f6510000-f6513fff
WARNING: output may be incomplete or inaccurate, you should run this program as super-user.
It looks like you have a relatively new network card. Linux in general works best with a machine on a bit older side because of the time needed volunteers working on the new hardware.
I forgot to mention.
To solve the internet connection, you got be able to connect to the internet
To solve this dilemma, I have a USB WiFi dongle which always works in Linux. They are quite inexpensive, around 5 to 6 Euro each. Look for the chipset either RT5370 or 8188cus (both are from Realtek).
I had a slightly different issue with the wifi, but that solution did not work on 16. I never did get the wired connection working on 15.3 but because wifi was working fine I just left it. I'm going to try running through some of the suggestions above and will mark which one works. Thanks everyone.
Please keep in mind that whenever you Upgrade the kernel, due to dkms, you will need to repeat this procedure to reinstall your driver. So keep a copy of this in a .txt file your Documents for easy access, too.
I wrote several tutorials for this forum regarding installation and configuration of Zorin. Not only those tutorials help others, I know exactly where to look for next time I need those informations myself
