All I did just rebooting. Wired connection still connecting (connected to my router) but the WiFi still working, but it unstable. How do fix it? And yes, I replugged the cable
If you happen to have Broascom WiFi like myself, you need to use an additional driver. You can check it by opening "Additional Drivers" from Application menu.
I don't use Broascom WiFi. It keep disconnecting and connecting
Can you issue this command in terminal
lspci
and paste the output here?
This shows on output
00:00.0 Host bridge: Intel Corporation 4th Gen Core Processor DRAM Controller (rev 06)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v3/4th Gen Core Processor PCI Express x16 Controller (rev 06)
00:14.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB xHCI (rev 05)
00:16.0 Communication controller: Intel Corporation 8 Series/C220 Series Chipset Family MEI Controller #1 (rev 04)
00:1a.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB EHCI #2 (rev 05)
00:1b.0 Audio device: Intel Corporation 8 Series/C220 Series Chipset High Definition Audio Controller (rev 05)
00:1c.0 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #1 (rev d5)
00:1c.2 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #3 (rev d5)
00:1c.3 PCI bridge: Intel Corporation 82801 PCI Bridge (rev d5)
00:1c.5 PCI bridge: Intel Corporation 8 Series/C220 Series Chipset Family PCI Express Root Port #6 (rev d5)
00:1d.0 USB controller: Intel Corporation 8 Series/C220 Series Chipset Family USB EHCI #1 (rev 05)
00:1f.0 ISA bridge: Intel Corporation B85 Express LPC Controller (rev 05)
00:1f.2 SATA controller: Intel Corporation 8 Series/C220 Series Chipset Family 6-port SATA Controller 1 [AHCI mode] (rev 05)
00:1f.3 SMBus: Intel Corporation 8 Series/C220 Series Chipset Family SMBus Controller (rev 05)
01:00.0 VGA compatible controller: NVIDIA Corporation GM206 [GeForce GTX 960] (rev a1)
01:00.1 Audio device: NVIDIA Corporation GM206 High Definition Audio Controller (rev a1)
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 0c)
04:00.0 PCI bridge: ASMedia Technology Inc. ASM1083/1085 PCIe to PCI Bridge (rev 03)
06:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8192CE PCIe Wireless Network Adapter (rev 01)
This might help:
https://askubuntu.com/questions/34"RTL8192CE" ubuntu linux driver2076/step-by-step-ubuntu-12-04-install-of-realtek-rtl8188ce-driver#383990
[*] The build has failed! Please make sure you have all dependencies installed and you are building on the correct branch (kernel version, not linux distro version, is most important for the branch)
Can you try seeing if modprobe can pull it from the kernel?:
sudo modprobe -r rtl8192ce && sudo modprobe rtl8192ce
No need. So all I did is just connecting drive to VMware. I booted up, shut down and plug back to computer and now the Wired connection works. Weird ...
