Hello,
I've just upgraded to zorin 17 pro, with zorin 16.3 pro I was working with 2 screens, but to my disappointment it only recognises one screen.
I think it must be a problem with the graphics card recognised as <<llvmpipe (LLVM 15.0.7, 256 bits)>>. But it's a nvidia Gforce GT730.
It is recognised in the "Drivers" section of the "Update" software.
In Software & Updates
> Additional Drivers
, which Nvidia driver are you set to?
If available, can you test the 470 (Proprietary) driver?
I tried, but the option is stuck on "Continue using a manually installed driver", impossible to click!
Can you post a screenshot?
You may try:
sudo apt remove --purge '^nvidia-.*'
sudo ubuntu-drivers install
Problem solved, I ran your solution on the terminal.
Thank you so much.
