So much talk on here about WPS Office so I thought I would see what's it's about. I downloaded the deb install file, right clicked on "Open with Linux install application" and it never installs. The time clock just goes on and on and on and on . . . .
I tried several times after a "sudo apt update" and no dice. Anyone have any ideas?
I
Personally I prefer Free Office from Softmaker.
https://www.freeoffice.com/en/
Here is how to install WPS Office:
Or as French Press has stated using Gdebi Package Installer if you need a GUI (Graphical User Interface). Install via Terminal:
sudo apt-get install gdebi
or via Synaptic Package Manager available in Software Channel where you search for gdebi; you will need to install gdebi and gdebi-gtk.
In this particular instance the terminal method is more straightforward than using Synaptic.
Thanks FrenchPress - Gdebi worked fine, thanks!
Oh, I'm using FreeOffice now and love it, just wanted to see WPS. Thanks . . .
Just to let everyone know, I tried WPS Office for a few hours, uninstalled and went back to FreeOffice. So much easier . . . I really did try
Yup. That is the right attitude ![]()
When it comes to the final judgement, you are the best judge of your own settings and use cases ![]()
The only downside I could find with WPS is the lack of language support for my language. I'm talking about spellchecker
