First, thanks to whoever replies here. I am wrapping up a fresh (and final) install of Zorin OS 17 Pro on my PC, and need to ask about three issues before I can consider this installation truly "complete." See below, please ...
For the built-in screen recording, when I start to record video, there is nothing I see that will enable me to stop recording. No visual input as to what key combination I could press to stop, nor is there any "stop" button I can press anywhere on the screen. I have to log off to just get my PC to stop recording video. Is this a bug? Or is it my PC? (Doubt it, but you never know.) The image capture works fine, though. Clear as a bell as to how to use it.
Previously, in another forum message, I'd asked how to uninstall LibreOffice. Someone provided a solution, which worked great. However, in what is a small annoyance, the "New Document" menu entry in the desktop context menu still retains LibreOffice entries. How do I get rid of these? For now, I have left LibreOffice on my new Zorin OS install, and am willing to live with it if I cannot easily get rid of the context menu entries.
For whatever reason, my screen goes dark after 5 minutes of gaming (without touching the mouse) on my gamepad. This is directly correlative with the power settings (which are set to turn off the monitor after 5 minutes of inactivity). Why aren't the power settings respecting my other activities on the computer while I don't use the mouse? What can I do to fix this? To that end, I've heard of this program called "Caffeine." Do I install that? Or is there another way to resolve this problem without having to install an app just to restore the intended functionality?
Again, thank you to anyone who responds. Happy I bought Zorin OS Pro.
Just need to take care of these last few remaining items ...
It is recording, yes. I have to log off, then sign back on just to regain control of the desktop. The screencasts are successfully saved in the "videos" folder. So ... yeah.
I am using desktop layout 4 (gnome). If you're not, that might account for it.
Also, it's reported that this default screen recorder does not record audio. For that reason, you may want something else:
Possibilities:
GPU Recorder recommended in a previous post. (I haven't used this myself)
Simple Screen Recorder. I have only used this app. But, it only works with X11 session, not Wayland. If you are interested, this package is in the Software Store, as:
"SimpleScreenRecorder (UNOFFICIAL)"
Be sure to select the Zorin OS package, not the snap package.
It actually doesn't work. What I mean by not "work," I mean that I can't tell if the program is running or not. There are no icons to be seen (like the coffee cup) that tell me that it's activated, at least. No nothing. Unfortunate ...
Hi, Aravisian. No. Once I saw that nothing was happening, I didn't pursue it any further on Zorin. I did try installing Caffeine on a live USB session of Linux Mint, and it worked perfectly. The icon came up fine in the taskbar ("panel" on Mint).
I would recommend trying it out. Caffeine is harmless and can be removed if it is not working out.
I never had a panel icon for it; I guess that is just a variable - with the icon you can disable or enable it at need whereas on my system, it just stayed enabled.
I can also recommend Caffeine. It had a panel Icon the first time I launched it. Since then it runs in the background without any notices and prevents the screen from going to sleep. I probably will never understand why this isnt a feature out of the box but its a good workaround for now.
I noticed just now that I only have an icon if I start the "caffeine indicator". Otherwise it runs in the background without an icon. I probably have remembered wrong how it behaved when I installed it. Like I said it runs now without an icon and I prefer it that way.
Yeah it is weird. The screen recorder used to work, and then one day it just stopped. I don't get the little 'stop record' button, nor does any new file appear in screencasts. Not sure what happened but I used to use it a lot.
