With the steamplay updates and Baldur's Gate 3 updates - The game works flawlessly in Zorin OS 16.
Tested on: | AMD Ryzen 1700x 3.4 GHz | ASUS PRIME X370-A | 32 GB 2400 Mhz DDR4 | ASUS Nvidia 1070 8 GB | SSD 1000 GB |
Hi
Would you mind sharing which nvidia driver version you are using to run the game and which compatibility tool you are using with Steam ? For some reason, the game worked perfectly well for me during the first mission, and then abruptly crashed. I haven't been able to relaunch the game since.
Thanks ahead for your feedback !
I can't recall it I'm on Ubuntu Budgie and Fedora now.
Are you using .deb or flatpak of Steam?
I'm using the .deb version
The i386 libs may getting to old for Steam (and its games). Try the flatpak and see if it solve the problem.
It took some time to successfully switch to the flatpak version of Steam, but unfortunately, the game still does not work. Thanks anyway for the piece of advice.
