Okay, then You should try it with the .deb Versions. Flatpaks run in Containers and that can cause Issues - it don't have to but can. So, You could try it with Firefox first because this is available as .deb directly from the Mozilla-own Repo in Zorin 17.2. You can install it with sudo apt install firefox in the Terminal (theoretically it comes already preinstalled).
I checked the Mozilla version and I found out it is not installed, but a "snap version" if I understood well. Still I install it on terminal?
It isn't available ... did You installed Zorin before Version 17.2? Because then it isn't included and You would have to manually add the Mozilla Repo. I personally wouldn't recommend the Snap Version but You could try it with that one and look if the Performance is better.
Or You could add the Mozilla Repo manually with the Guide from Mozilla:
It looks a bit overwhelming, I know. But it is a Step-by-Step Guide what gives You the Commands that You need. Of Course, You shouldn't simply use any Commands that You find somewhere in the Internet from random Persons. But here it comes from Mozilla directly.
I saw it again and it's odd. I don't have a snap Firefox (checked on terminal), actually. It isn't even installed, but it's available. Is it normal or something is not right? Anyway, I'll do it.
Firefox provided with earlier Z17 was a Flatpak.
I'm back. Happy new year to you all! Work get me hard.
I dropped Firefox and went again to Brave, which I am used to. I had installed it on terminal and works pretty fine. But there is something strange I've been noticing for both Brave and Chromium: every time I take a tab and drag it outside the browser to get another one window, this one becomes white and buggy in an odd way. What it can be?
