ZFS is the penultimate file system, but there exists one glaring flaw... there is no in-built way nor are there many open-source and free-as-in-beer and easily-used snapshot management applications. We're left with creating or co-opting and modifying a bash script to suit that purpose.
That's what I've done. I found this bash script online, but it wouldn't run, so I got it running.
Copy the code (below), paste it into a Text Editor window. Save it to your Desktop as zfsflush.sh
Right-click the file, select Properties, select Permissions, select the 'Allow executing file as program' checkbox, click 'x' at upper-right to exit Properties.
In Terminal: sudo nautilus
In Nautilus: navigate to Other Locations/Computer/usr/local/bin
Click-n-hold on the zfsflush.sh file on the Desktop and drag it into that /bin directory.
Delete the copy of zfsflush.sh on the Desktop.
Now you can run that bash script from within Terminal.
Here's how I use it:
zfsflush.sh -d 15 -p bpool
zfsflush.sh -d 15 -p rpool
-d: number of days old the snapshot must be to get flushed
-p: the name of the pool (in our case, bpool and rpool)
The code:
#!/usr/bin/env bash
usage="$(basename "$0") -s SECONDS -m MINUTES -h HOURS -d DAYS -p GREP_PATTERN [-t]\n
arguments:\n
-s delete snapshots older than SECONDS\n
-m delete snapshots older than MINUTES\n
-h delete snapshots older than HOURS\n
-d delete snapshots older than DAYS\n
-p the grep pattern to use\n
-t test run, do not destroy the snapshots just print them
while getopts ":ts:m:h:d:p:" opt; do
case $opt in
s)
seconds=$OPTARG
m)
minutes=$OPTARG
h)
hours=$OPTARG
d)
days=$OPTARG
p)
pattern=$OPTARG
t)
test_run=true
echo "Invalid option: -$OPTARG" 1>&2
echo -e $usage 1>&2
exit 1
echo "Option -$OPTARG requires an argument." 1>&2
echo -e $usage 1>&2
exit 1
esac
done
if [[ -z $pattern ]]; then
echo -e "No grep pattern supplied\n" 1>&2
echo -e $usage 1>&2
exit 1
fi
if [[ -z $days ]]; then
days=0
fi
if [[ -z $hours ]]; then
hours=0
fi
if [[ -z $minutes ]]; then
minutes=0
fi
if [[ -z $seconds ]]; then
seconds=0
fi
# Figure out which platform we are running on, more specifically, whic version of date
# we are using. GNU date behaves different thant date on OSX and FreeBSD
platform='unknown'
unamestr=$(uname)
if [[ "$unamestr" == 'Linux' ]]; then
platform='linux'
elif [[ "$unamestr" == 'FreeBSD' ]]; then
platform='bsd'
elif [[ "$unamestr" == 'OpenBSD' ]]; then
platform='bsd'
elif [[ "$unamestr" == 'Darwin' ]]; then
platform='bsd'
else
echo -e "unknown platform $unamestr 1>&2"
exit 1
fi
compare_seconds=$(($days * 24 * 60 * 60 + $hours * 60 * 60 + $minutes * 60 + $seconds))
if [ $compare_seconds -lt 1 ]; then
echo -e time has to be in the past 1>&2
echo -e $usage 1>&2
exit 1
fi
if [[ "$platform" == 'linux' ]]; then
compare_timestamp=`date --date="-$(echo $compare_seconds) seconds" +"%s"`
else
compare_timestamp=`date -j -v-$(echo $compare_seconds)S +"%s"`
fi
# get a list of snapshots sorted by creation date, so that we get the oldest first
# This will allow us to skip the loop early
snapshots=`zfs list -H -t snapshot -o name,creation -s creation | grep $pattern`
if [[ -z $snapshots ]]; then
echo "no snapshots found for pattern $pattern"
exit 0
fi
# for in uses \n as a delimiter
old_ifs=$IFS
IFS=$'\n'
for line in $snapshots; do
snapshot=`echo $line | cut -f 1`
creation_date=`echo $line | cut -f 2`
creation_date_timestamp=`date --date="$creation_date" "+%s"`
else
creation_date_timestamp=`date -j -f "%a %b %d %H:%M %Y" "$creation_date" "+%s"`
fi
# Check if the creation date of a snapshot is less than our compare date
# Meaning if it is older than our compare date
# It is younger, we can stop processing since we the list is sorted by
# compare date '-s creation'
if [ $creation_date_timestamp -lt $compare_timestamp ]
then
if [[ -z $test_run ]]; then
echo "DELETE: $snapshot from $creation_date"
sudo zfs destroy $snapshot
else
echo "WOULD DELETE: $snapshot from $creation_date"
fi
else
echo "KEEP: $snapshot from $creation_date"
echo "No more snapshots to be processed for $pattern. Skipping.."
break
fi
done
IFS=$old_ifs
