I installed Zorin 16.2 Pro version. My mouse right clicks randomly. I am using the Logitech Wireless Keyboard and mouse. My Dell desktop is touchscreen ( I disabled the touch screen ).
From Settings > Accessibility, ensure that Click Assist (Click on hover) is not enabled.
If that is not it, you may need to adjust mouse sensitivity.
Last thing to try is: A different mouse. See if a USB or different wireless mouse shows the same problem.
Try different USB ports. I have logitech wireless keyboard and mouse and I had to changed ports or else I would loose connection from time to time. It could be something to do which version of the USB ports are.
Thanks. I will try that.
