Zorin 16 Beta - Grub menu does not show
Installed ok but caused Windows to Green Screen. Had to run windows repair and fixed so would boot. Goes straight to Windows 10...Newbie here so not sure what to do to get Grub menu to show. I have tried the command line prompt from windows and did not fix. I ran Zorin live from usb and run boot repair.
boot-repair-4ppa130 [20210418_1822]
============================== Boot Info Summary ===============================
md/imsm0: ______________________________________________________________________
File system:
Boot sector type:  Unknown
Boot sector info:
md/imsm1: ______________________________________________________________________
File system:
Boot sector info:
sda: ___________________________________________________________________________
File system:       iso9660
Boot sector info:
Mounting failed:   mount: /mnt/BootInfo/FD/sda: /dev/sda already mounted or mount point busy.
================================ 0 OS detected =================================
============================ Architecture/Host Info ============================
CPU architecture: 64-bit
Live-session OS is Zorin 64-bit (Zorin OS 16, focal, x86_64)
===================================== UEFI =====================================
BIOS is EFI-compatible, and is setup in EFI-mode for this live-session.
SecureBoot disabled.
efibootmgr -v
BootCurrent: 0001
Timeout: 0 seconds
BootOrder: 0000,0001,2001,2002,2003
Boot0000* Windows Boot Manager HD(1,GPT,e4cf9e3f-9154-41ac-9f84-b663ed74830a,0x800,0x82000)/File(\EFI\Microsoft\Boot\bootmgfw.efi)RC
Boot0001* Linpus lite HD(1,MBR,0x60170b8d,0x254,0x2700)/File(\EFI\Boot\grubx64.efi)RC
Boot2001* EFI USB Device RC
Boot2002* EFI DVD/CDROM RC
Boot2003* EFI Network RC
This session has been detected as 'live' because /proc/cmdline contains (boot=casper)
This session has been detected as 'live' because df -Th / contains overlay
============================= Drive/Partition Info =============================
Disks info: ____________________________________________________________________
nvme0n1 : is-GPT, no-BIOSboot, has---ESP, not-usb, not-mmc, no-os, 2048 sectors * 512 bytes
nvme1n1 : notGPT, no-BIOSboot, has-noESP, not-usb, not-mmc, no-os, 2048 sectors * 512 bytes
Partitions info (1/3): _________________________________________________________
nvme0n1p1 : no-os, 32, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, not-far
nvme0n1p3 : no-os, 32, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, farbios
nvme0n1p4 : no-os, 32, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, farbios
nvme0n1p5 : no-os, 32, nopakmgr, no-docgrub, nogrub, nogrubinstall, no-grubenv, noupdategrub, farbios
Partitions info (2/3): _________________________________________________________
nvme0n1p1 : is---ESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot
nvme0n1p3 : isnotESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot
nvme0n1p4 : isnotESP, part-has-no-fstab, no-nt, no-winload, no-recov-nor-hid, no-bmgr, notwinboot
nvme0n1p5 : isnotESP, part-has-no-fstab, no-nt, no-winload, recovery-or-hidden, no-bmgr, notwinboot
Partitions info (3/3): _________________________________________________________
nvme0n1p1 : not-sepboot, no-boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, std-grub.d, nvme0n1
nvme0n1p3 : not-sepboot, no-boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, std-grub.d, nvme0n1
nvme0n1p4 : not-sepboot, no-boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, std-grub.d, nvme0n1
nvme0n1p5 : not-sepboot, no-boot, part-has-no-fstab, not-sep-usr, no---usr, part-has-no-fstab, std-grub.d, nvme0n1
fdisk -l (filtered): ___________________________________________________________
Disk nvme0n1: 476.96 GiB, 512110190592 bytes, 1000215216 sectors
Disk identifier: 467BAFF6-6891-4925-ABCE-D2FC5B64F010
Start End Sectors Size Type
nvme0n1p1 2048 534527 532480 260M EFI System
nvme0n1p2 534528 567295 32768 16M Microsoft reserved
nvme0n1p3 567296 936716287 936148992 446.4G Microsoft basic data
nvme0n1p4 936716288 998154239 61437952 29.3G Microsoft basic data
nvme0n1p5 998156288 1000204287 2048000 1000M Windows recovery environment
Disk nvme1n1: 27.26 GiB, 29260513280 bytes, 57149440 sectors
Disk sda: 3.65 GiB, 3904897024 bytes, 7626752 sectors
Disk identifier: 0x60170b8d
Boot Start End Sectors Size Id Type
sda1 * 0 5222399 5222400 2.5G 0 Empty
sda2 596 10579 9984 4.9M ef EFI (FAT-12/16/32)
sda3 5222400 7626751 2404352 1.2G 83 Linux
parted -lm (filtered): _________________________________________________________
sda:3905MB:scsi:512:512:msdos:JetFlash Transcend 4GB:;
2:305kB:5417kB:5112kB:::esp;
3:2674MB:3905MB:1231MB:ext4::;
nvme0n1:512GB:nvme:512:512:gpt:INTEL HBRPEKNX0202AL:;
1:1049kB:274MB:273MB:fat32:EFI system partition:boot, esp;
2:274MB:290MB:16.8MB::Microsoft reserved partition:msftres;
3:290MB:480GB:479GB:ntfs:Basic data partition:msftdata;
4:480GB:511GB:31.5GB:ntfs:Basic data partition:msftdata;
5:511GB:512GB:1049MB:ntfs:Basic data partition:hidden, diag;
nvme1n1:29.3GB:nvme:512:512:unknown:INTEL HBRPEKNX0202ALO:;
blkid (filtered): ______________________________________________________________
NAME FSTYPE UUID PARTUUID LABEL PARTLABEL
sda iso9660 2021-04-15-12-16-44-00 Zorin OS 16 Core Beta 64bit
├─sda1 iso9660 2021-04-15-12-16-44-00 60170b8d-01 Zorin OS 16 Core Beta 64bit
├─sda2 vfat EA78-DE30 60170b8d-02
└─sda3 ext4 d6b0c3cc-7dcd-42b0-8475-cb10fa3f450f 60170b8d-03 writable
nvme0n1 isw_raid_member
├─nvme0n1p1 vfat D251-9755 e4cf9e3f-9154-41ac-9f84-b663ed74830a SYSTEM_DRV EFI system partition
├─nvme0n1p2 0c54be26-bbad-48ba-9283-14000fc10f61 Microsoft reserved partition
├─nvme0n1p3 ntfs 56A25237A2521BB5 a94a87c7-179a-4a39-a8f4-935372adebac Windows-SSD Basic data partition
├─nvme0n1p4 ntfs E26421D06421A86D 97874989-85d4-43dc-a588-50a9bc9491e5 Linux Basic data partition
└─nvme0n1p5 ntfs 7A5A574A5A5701F5 2d20e3fa-6ebb-4f1b-9167-83d1a7f934b2 WINRE_DRV Basic data partition
nvme1n1 isw_raid_member
df (filtered): _________________________________________________________________
                                                     Avail Use% Mounted on
disk/by-label/writable[/install-logs-2021-04-18.6/crash] 1G 2% /var/crash
disk/by-label/writable[/install-logs-2021-04-18.6/log] 1G 2% /var/log
sda1 0 100% /cdrom
Mount options: __________________________________________________________________
disk/by-label/writable[/install-logs-2021-04-18.6/crash] rw,relatime
disk/by-label/writable[/install-logs-2021-04-18.6/log] rw,relatime
sda1 ro,noatime,nojoliet,check=s,map=n,blocksize=2048
======================== Unknown MBRs/Boot Sectors/etc =========================
Unknown BootLoader on md/imsm0
Unknown BootLoader on md/imsm1
Unknown BootLoader on sda
00000000 33 ed 90 90 90 90 90 90 90 90 90 90 90 90 90 90 |3...............|
00000010 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 90 |................|
00000020 33 ed fa 8e d5 bc 00 7c fb fc 66 31 db 66 31 c9 |3......|..f1.f1.|
00000030 66 53 66 51 06 57 8e dd 8e c5 52 be 00 7c bf 00 |fSfQ.W....R..|..|
00000040 06 b9 00 01 f3 a5 ea 4b 06 00 00 52 b4 41 bb aa |.......K...R.A..|
00000050 55 31 c9 30 f6 f9 cd 13 72 16 81 fb 55 aa 75 10 |U1.0....r...U.u.|
00000060 83 e1 01 74 0b 66 c7 06 f3 06 b4 42 eb 15 eb 02 |...t.f.....B....|
00000070 31 c9 5a 51 b4 08 cd 13 5b 0f b6 c6 40 50 83 e1 |1.ZQ....[...@P..|
00000080 3f 51 f7 e1 53 52 50 bb 00 7c b9 04 00 66 a1 b0 |?Q..SRP..|...f..|
00000090 07 e8 44 00 0f 82 80 00 66 40 80 c7 02 e2 f2 66 |..D.....f@.....f|
000000a0 81 3e 40 7c fb c0 78 70 75 09 fa bc ec 7b ea 44 |.>@|..xpu....{.D|
000000b0 7c 00 00 e8 83 00 69 73 6f 6c 69 6e 75 78 2e 62 ||.....isolinux.b|
000000c0 69 6e 20 6d 69 73 73 69 6e 67 20 6f 72 20 63 6f |in missing or co|
000000d0 72 72 75 70 74 2e 0d 0a 66 60 66 31 d2 66 03 06 |rrupt...ff1.f..| 000000e0 f8 7b 66 13 16 fc 7b 66 52 66 50 06 53 6a 01 6a |.{f...{fRfP.Sj.j| 000000f0 10 89 e6 66 f7 36 e8 7b c0 e4 06 88 e1 88 c5 92 |...f.6.{........| 00000100 f6 36 ee 7b 88 c6 08 e1 41 b8 01 02 8a 16 f2 7b |.6.{....A......{| 00000110 cd 13 8d 64 10 66 61 c3 e8 1e 00 4f 70 65 72 61 |...d.fa....Opera| 00000120 74 69 6e 67 20 73 79 73 74 65 6d 20 6c 6f 61 64 |ting system load| 00000130 20 65 72 72 6f 72 2e 0d 0a 5e ac b4 0e 8a 3e 62 | error...^....>b| 00000140 04 b3 07 cd 10 3c 0a 75 f1 cd 18 f4 eb fd 00 00 |.....<.u........| 00000150 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 |................| * 000001b0 54 29 00 00 00 00 00 00 8d 0b 17 60 00 00 80 00 |T).............|
000001c0 01 00 00 9f e0 fb 00 00 00 00 00 b0 4f 00 00 fe |............O...|
000001d0 ff ff ef fe ff ff 54 02 00 00 00 27 00 00 00 14 |......T....'....|
000001e0 50 45 83 bd 63 da 00 b0 4f 00 00 b0 24 00 00 00 |PE..c...O...$...|
000001f0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 55 aa |..............U.|
00000200
=============================== StdErr Messages ================================
File descriptor 63 (pipe:[81390]) leaked on lvs invocation. Parent PID 7831: /bin/bash
mdadm: (IMSM): Unsupported attributes : 3000000
mdadm: Unsupported attributes in IMSM metadata.Arrays activation is blocked.
mdadm: Cannot activate member /md127/0 in /dev/md/imsm0.
mdadm: Cannot activate member /md126/0 in /dev/md/imsm1.
mdadm: Cannot activate member /md126/1 in /dev/md/imsm1.
=================== blkid (filtered) before raid activation: ===================
/dev/nvme0n1p1: LABEL="SYSTEM_DRV" UUID="D251-9755" TYPE="vfat" PARTLABEL="EFI system partition" PARTUUID="e4cf9e3f-9154-41ac-9f84-b663ed74830a"
/dev/nvme0n1p3: LABEL="Windows-SSD" UUID="56A25237A2521BB5" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="a94a87c7-179a-4a39-a8f4-935372adebac"
/dev/nvme0n1p4: LABEL="Linux" UUID="E26421D06421A86D" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="97874989-85d4-43dc-a588-50a9bc9491e5"
/dev/nvme0n1p5: LABEL="WINRE_DRV" UUID="7A5A574A5A5701F5" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="2d20e3fa-6ebb-4f1b-9167-83d1a7f934b2"
/dev/nvme1n1: TYPE="isw_raid_member"
/dev/sda1: UUID="2021-04-15-12-16-44-00" LABEL="Zorin OS 16 Core Beta 64bit" TYPE="iso9660" PTUUID="60170b8d" PTTYPE="dos" PARTUUID="60170b8d-01"
/dev/sda2: SEC_TYPE="msdos" UUID="EA78-DE30" TYPE="vfat" PARTUUID="60170b8d-02"
/dev/sda3: LABEL="writable" UUID="d6b0c3cc-7dcd-42b0-8475-cb10fa3f450f" TYPE="ext4" PARTUUID="60170b8d-03"
/dev/nvme0n1p2: PARTLABEL="Microsoft reserved partition" PARTUUID="0c54be26-bbad-48ba-9283-14000fc10f61"
dmraid -si -c
no block devices found
dmraid -ay:
dmraid -sa -c:
mdadm --assemble --scan
mdadm --detail --scan
ARRAY /dev/md/imsm0 metadata=imsm UUID=f052041e:2a899191:b974d0c2:79038cdf
ARRAY /dev/md/imsm1 metadata=imsm UUID=fef4377d:9e26d322:d690a568:5cf10f75
Error code 32
mount -r /dev/nvme0n1p1 /mnt/boot-sav/nvme0n1p1
mount -r /dev/nvme0n1p1 : Error code 32
Error code 21
mount -r /dev/nvme0n1p3 /mnt/boot-sav/nvme0n1p3
mount -r /dev/nvme0n1p3 : Error code 21
Error code 21
mount -r /dev/nvme0n1p4 /mnt/boot-sav/nvme0n1p4
mount -r /dev/nvme0n1p4 : Error code 21
Error code 21
mount -r /dev/nvme0n1p5 /mnt/boot-sav/nvme0n1p5
mount -r /dev/nvme0n1p5 : Error code 21
Error code 32
Error code 21
Error code 21
Error code 21
Suggested repair: ______________________________________________________________
The default repair of the Boot-Repair utility would not act on the boot.
In case needed, it's a Lenovo C940
Blockquote
Thanks, I didn't even think of raid. It has the Intel Optane Storage? Is that it and I need to disable it?
Intel Optane Memory | Speed Up Your PC | Lenovo US
Yeah, I will turn off in Bios and then try again. Thanks for the article as well, That looks very helpful, I might try that as well.
I think I will hold off on windows in VM for now and just turn off in windows as well..I screwed up and deleted the partition that was created for Zorin and it hosed my windows as well...so tonights project is reinstall windows and then Zorin..I know I have to do Windows 1st to dual boot.
Thanks for the help. Worked great. Would have never figured out the Intel Optane issue on my own :wink: I went with 15, I assume no auto way to upgrade to beta 16 correct? Now to get playing!!
also i cannot complete the installation, grub-efi-amd64-package failed during installation.
We understand the devs are planning to enable upgrade from Z15.3 to Z16 via the normal software update process, but that will not be until later in the year, after Z16 production versions are released.
Please do not cross-post. Your post is already addressed by Aravisian.
