Good morning
Zorin 16 the Settings application cannot be opened suddenly .... Settings do not respond
When I press settings I get this: gnome-control-center
Good morning
That I feel like is the real name of settings.
Have you tried opening settings through terminal?
Type gnome-control-center
in terminal.
With this option sudo apt install gnome-control-center in the terminal with its settings ... ok
Thanks for the help
Can you rephrase? I did not understand.
May be his gnome-control-center was uninstalled.
Maybe that could have been the issue. Icons sometimes does appear even after uninstalling. Even I have two of the "leftover" icons of vlc and brave. Never tried to remove them but I will.
