Just installed Lite Pro and is it just me or did something change with the taskbar icon size? They seem to be various sizes. All icons on right side seem much larger than app icons on left. Any ideas on how to fix?
Right click the panel and open Panel Preferences
Move to the Items Tab
Click on the Notifications Plugin or the Power manager plugin or the Plugin that has sizes different than the sizes of icons you want...
Now click the Settings
icon on the bottom toolbar of the popup window.
Disable Adjust size automatically" under
Icons`
Select a Fixed Size.
Perform this on any plugins that need it.
Worked perfectly! Thanks Aravisian . . .
