Zorin 17 Pro to 18 Pro Failed with DBus Error
While attempting to use the updater to go from 17.3 to 18 Pro (using purchased key) I'm getting errors that ultimately seem to boil down to the DBus. All updates are up to date and I moved all 3rd party sources to a backup folder.
[CHECKING] Started
[CHECKING:Validating Upgrade Attempt] Started
[CHECKING:Validating Upgrade Attempt] Completed
[CHECKING:Checking Filesystem] Started
[CHECKING:Checking Filesystem] Completed
[CHECKING:Creating Necessary Files] Started
[CHECKING:Creating Necessary Files] Completed
[CHECKING:Adding GPG Keys] Started
[CHECKING:Adding GPG Keys] Completed
[CHECKING:Restarting Apt] Started
[CHECKING:Restarting Apt] Completed
[CHECKING:Simulating Flatpak Transaction] Started
[CHECKING:Simulating Flatpak Transaction] Completed
[CHECKING:Processing Apt Repos] Started
[CHECKING:Processing Apt Repos] Completed
[CHECKING:Updating Apt Repos] Started
[CHECKING:Updating Apt Repos] Retrying
[CHECKING:Updating Apt Repos] Fatal Error: { GDBus.Error:org.freedesktop.DBus.Error.NoReply: Message recipient disconnected from message bus without replying }
[CHECKING:Updating Apt Repos] Failed
[CHECKING] Failed
[CHECKING:Restoring System] Started
[CHECKING:Restoring System] Error: { GDBus.Error:org.freedesktop.DBus.Error.NoReply: Message recipient disconnected from message bus without replying }
[CHECKING:Restoring System] Completed
In the rare case anyone else runs into this error it was caused by the 'wrong' version of Python being installed on my system. Uninstalled that version, installed the apt python version and Bob's your uncle!
I marked your second post as :white_check_mark:Solution. So that it may then be easily seen by others.
