is there any way to get web cam reconised
What is the webcam make/model, and lenovo model concerned?
Thanks for reply make Lenovo Mix510 web not recognize in cheese or other apps
Is the camera showing in the output in terminal for lsusb
or lspci
Here is the results, i didnt see it.. this is my 1st trime using Linux , thanks for the support.
andy@Andy-MIIX-510-12IKB:~$ lsusb
Bus 001 Device 004: ID 04f2:1622 Chicony Electronics Co., Ltd Lenovo HID Device
Bus 001 Device 003: ID 8087:0a2b Intel Corp. Bluetooth wireless interface
andy@Andy-MIIX-510-12IKB:~$ lspci
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers (rev 02)
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 620 (rev 02)
00:04.0 Signal processing controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem (rev 02)
00:05.0 Multimedia controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Imaging Unit (rev 01)
00:14.0 USB controller: Intel Corporation Sunrise Point-LP USB 3.0 xHCI Controller (rev 21)
00:14.2 Signal processing controller: Intel Corporation Sunrise Point-LP Thermal subsystem (rev 21)
00:14.3 Multimedia controller: Intel Corporation CSI-2 Host Controller (rev 01)
00:15.0 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO I2C Controller #0 (rev 21)
00:15.1 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO I2C Controller #1 (rev 21)
00:15.2 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO I2C Controller #2 (rev 21)
00:15.3 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO I2C Controller #3 (rev 21)
00:16.0 Communication controller: Intel Corporation Sunrise Point-LP CSME HECI #1 (rev 21)
00:17.0 SATA controller: Intel Corporation Sunrise Point-LP SATA Controller [AHCI mode] (rev 21)
00:1c.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #4 (rev f1)
00:1c.5 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #6 (rev f1)
00:1d.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #9 (rev f1)
00:1f.0 ISA bridge: Intel Corporation Sunrise Point LPC Controller/eSPI Controller (rev 21)
00:1f.2 Memory controller: Intel Corporation Sunrise Point-LP PMC (rev 21)
00:1f.3 Audio device: Intel Corporation Sunrise Point-LP HD Audio (rev 21)
00:1f.4 SMBus: Intel Corporation Sunrise Point-LP SMBus (rev 21)
01:00.0 Network controller: Intel Corporation Wireless 8265 / 8275 (rev 78)
02:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS5229 PCI Express Card Reader (rev 01)
03:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM961/PM961/SM963
Here
Looks like this is your webcam.
Which seems to be a troublesome device:
This is not surprising in itself... In recent years, Lenova has become increasingly GnuLinux unfriendly.
You may be better off grabbing an inexpensive USB webcam.
Thanks for helping i really appreciate it, your a legend... happy to buy a web cam. very happy with liniux though 7 the Community around it
cheers
Suggesting a hardware fault or that a user must buy a network adapter or camera is usually my last resort.
I prefer it be a software issue because those are generally free to fix and do not require disassembly or using a voltmeter.
Sometimes, you have to accept when you are licked, though.
