Zorin 18 fails to boot. Recovery launched and restart to Xorg works
I just booted my desktop this morning and it hung on the Zorin splash screen.
I rebooted to recovery and got the recovery box asking me what to do.
I selected resume and it seems I am now booted into the Xorg session. I have been logging into the Wayland session previously.
I updated all software from the software updater.
When I reboot now, I see the Zorin logo and get a black screen which forces me to recovery again and back into the Xorg session.
I opened logs and see these messages:
11:47:40 AM gdm3: Gdm: on_display_removed: assertion 'GDM_IS_REMOTE_DISPLAY (display)' failed
11:47:37 AM systemd: Failed to start app-gnome-gnome\x2dkeyring\x2dpkcs11-2633.scope - Application launched by gnome-session-binary.
11:47:34 AM gdm3: Gdm: on_display_added: assertion 'GDM_IS_REMOTE_DISPLAY (display)' failed
11:47:34 AM gdm-session-wor: gkr-pam: unable to locate daemon control file
11:47:13 AM deluser: The user `cc-plugin-user' does not exist.
11:47:10 AM (sd-exec-strv): /usr/lib/systemd/system-generators/friendly-recovery failed with exit status 1.
11:46:58 AM kernel:
11:46:57 AM kernel: thunderbolt 0000:06:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0012 address=0xaad93900 flags=0x0020]
System info:
System Details Report
Report details
  • Date generated: 2026-03-31 12:31:09
Hardware Information:
  • Hardware Model: ASUS ProArt B550-CREATOR
  • Memory: 128.0 GiB
  • Processor: AMD Ryzen™ 9 5950X × 32
  • Graphics: NVIDIA L40S
  • Graphics 1: NVIDIA L40S
  • Disk Capacity: 8.0 TB
Software Information:
  • Firmware Version: 4001
  • OS Name: Zorin OS 18 Pro
  • OS Build: (null)
  • OS Type: 64-bit
  • Windowing System: X11
  • Kernel Version: Linux 6.17.0-19-generic
Any idea how I can resolve this?
Did You received any Updates?
I would suggest first to try it with switching to an older Kernel. You can do that on the GRUB Menu on Startup. choose there ''Advanced Options'' and there the older Kernel.
Another Thing could be that maybe gdm has an Issue. You could try it with a Reinstall: sudo apt reinstall gdm3
Can You say what Graphics Card You have and what Driver You use?
Thanks! I'll try those options as soon as I can.
I took updates several days ago. But I cannot remember if I performed a reboot since then. I shutdown last night. And started up today to this issue. The only other differences were a couple flatpaks I installed. I uninstalled those today in the course of troubleshooting just to rule them out.
2GPUs:
1 - Nvidia L40s for machine learning/Ai
2 - Nvidia RTX 2060 Super powering 2 display port monitors
Driver = 580.126.09
@Ponce-De-Leon
I suspected what you said about reinstalling gdm3 might work. So, I tried that first and it did work. I am booting normally again. Thanks!
Additionally, it also resolved another issue I had of only seeing the colored splash screen during login on my primary monitor. Before this issue, the login screen was black and the blurred color screen only showed on the 2nd monitor.
Unfortunately though, I'm still having some issues that I think may be Wayland related.
1 - FreeTube(flatpak) will not show my normal size mouse cursor. It shows a tiny mouse cursor that I am barely able to see. When I move the mouse outside of the app, the cursor is normal.
2 - Audio playback has a constant popping/crackling sound much like a vinyl record.
Both of those issues go away when I login with Xorg.
Did You tried it with the .deb Version?
Did You tried Pulse Audio Volume Control? You can install it with the Command sudo apt install pavucontrol
After Installation, checkt the Configuration and Output Tab and check there what Audio Profiles are available and try if something changes.
OK. I'll try those things next and report back.
Thanks!
@Ponce-De-Leon
Sorry for the delay. I wound up re-installing Zorin. I was having way too many graphical issues.
Re-installing was fine for me since it fits with my setup plan anyway. Anytime I move to a new OS, new PC etc., I don't do anything important for a while. I just hammer down on getting to know the OS itself and document each change I make for future reference.
I'm now logging in with xorg since it appears nvidia drivers with Wayland are just not as stable. All the other issues I mentioned above are gone.
Thanks for the assist!
