Zorin appearance doesnt work as expected
Zorin os appearance I am not able to see the themes which I copied into .themes folder.
Try doing it from GNOME Tweaks. Run
sudo apt install -y gnome-tweaks
and going into the appearance tab.
Are the themes extracted?
Are they part of a master file and need to be separated into their individual Theme Folders?
Thanks for the reply I solved this issue.
Can you please mark the reply that helped you as "Solution" (hit the "..." under the post) or add a post to describe how you solved the issue.
