Can someone help. I used the windows like theme and it went missing.
Try with;
sudo apt install --reinstall zorin-appearance-layouts-shell-core zorin-appearance-layouts-support
Thank you for a fast replay but it didn't work for me.
You could try:
sudo apt reinstall zorin-os-desktop
Or You could try to reinstall the whole Zorin Appearance Program with:
sudo apt reinstall zorin-appearance
I forgot: Welcome to the Forum!
Thank you.
Doesn't work. I tried both.
Can you please try in terminal:
sudo apt install --reinstall zorin-appearance && sudo apt install --reinstall zorin-appearance-layouts-support
Once done, reboot and test...
Still not working.
Can you detail any actions you recall prior to the layouts going missing?
Running a command like sudo apt autoremove for example or installing certain software?
