Zorin build ISO procedure?
Hi, I would like to know the procedure for building Zorin OS ISOs; at first sight didn't find anything relevant on launchpad or github
Thats not in my wheelhouse, plus I'm not sure of the legality of what you suggest. @AZorin I think this ones for you buddy.
it is open source software, so as long as it's for personal use, why wouldn't it be? There are distros centered around building from source specifically
Yeah, I don't think there's a problem with doing so. Although I'm a bit hesitant to give any instructions since I'm not familiar with this myself :sweat_smile:
Same here, I've never done it as well, and I won't give advice on stuff I don't know, nor on stuff I'm not sure legality of. This is why Azorin is best to answer this, but might be too busy to answer right now.
