Is there a place I can find the color pallets used in Zorin appearance?
I've recently installed i3 and want to get a more cohesive look with window manager theme.
What I need is the hex numbers of the colors.
You can dig these directly out of the Zorin OS theme which you are using in the .css file.
If you specify which theme, I can help you look.
The short of it is; look up the class you want to identify the color of, then look at its background or background-color property.
Do you mean the Accent Colors?:
You could use a Color Picker like Eyedropper. You can find it in the Gnome Software Center as a Flatpak. Or You can use The Gnome Extension ''Color Picker''. Then You can look which Hexcode the Colors have. I would like to give You the Codes directly but I have (re)installed my System freshly (Thanks to the Ghost in the Machine) and I don't have installed it not yet.
I want to create a full theme based on each of them. That way what ever mood I'm in that day I can just comment each one out. Lol.
I didnt even think of doing that. That could help. But ideally I want to get the hexcode right from the themes. I notice that its more than just accent colors that change between the different themes.
Another method you might use is gpick. This is an application that you can hover the mouse over a colored field and it tells you the color in HEX or RDG that is displayed. A caveat is that it shows the displayed color, so a layered color will be displayed as a singular hex color rather than the individual layers.
For that You can use a Color Picker, too. @Aravisian named you gpick for this. I have used Eyedropper and that works too. Here a Look in the Gnome Software Center for this Program:
I already had Eyedropper installed and thats what I ended up using. I dont know why I didnt think of it. It was a lot simpliler than I had thought.
I'm using i3 with Ploybar and got the themes started for i3. I still need to work on the polybar and the neoretch configs a bit more.
This is what I have so far.
Thank you for the help!
