Hello guys,
How to make Zorin connect work with Zorin lite?
Is this possible?
Note : I don't want to use KDE connect (when installing a KDE app it installs the whole KDE suite)
The only way is to install kde-connect. It does not install the whole KDE suite. It only installs the needed dependencies for kde-connect.
I use kde-connect on Zorin OS lite. On the surface, it is virtually identical in looks and function as Zorin Connect.
Zorin Connect is built off of GSConnect, a Gnome-Shell Extension that is built off of KDE-Connect.
Since it is a Gnome-Shell Extension, there is no method by which it can be adapted to run on any other desktop than Gnome.
