Zorin Core on Hyper V window too small
I just successfully have Zorin Core 64 installed under W10 Hyper V. Everything looks ok except for the huge black border on the Zorin desktop view. I don't THINK I have sound either but haven't tested for sound. Just mentioning it.
Any help is immensely appreciated in advance.
Is Hyper V a virtualization?
I am sure you know more than I do. Thank you for the reply. Here is what I did:
  1. Activated Hyper V on W10 Pro machine.
  2. Noticed a default to install 3 versions of Ubuntu (Quick Create ... see screen shot)
  1. I ignored that and selected Local Installation Source and found the downloaded Zorin Core iso file.
  1. Configured that VM for 3072 MB mem. Host machine has 8192 MB
  2. Configured Firmware to shiff64.efi (file). I thought maybe it should be Hard Drive New VM (1) but went with default file instead.
Seems to work 'ok' except Zorin window is too small and no sound.
Did a little more research to find that those Ubuntu machines are customized somehow to run within Hyper V .... while Zorin probably isn't. But I don't know about all that.
Memory is the only settings I made to the Zorin VM. Thanks again. Not getting email notifications of replies. Sorry for the late reply.
Anyone know how to overcome these problems?
I conclude Zorin will not run under Hyper V. Will try it with Virtualbox. Closing this thread.
To every one on here Hyper-V is virtualization for OSs just like VMWare and Virtual Box. Hyper-V allows you to run virtual machines, just like the other common virtual machine programs. Hyper-V is my go to for Virtual Machines.
My goto is to use a GNU/Linux bare metal install and use Virtual Machine Manager, outshines Virtual Box by miles and whilst VB claims to support USB 3.0 it doesn't and if you need to add devices like USB, you just add it in Virtual Machine Manager. It is what I used to create screenshots for the Unofficial Manual for Zorin 17.
I just installed Zorin 17 in a hyper-v VM and it's running just fine. Full 1920x1080 on a 27 inch monitor.
I still think a bare metal install is better, then use virt-manager for other OS's. Virt-manager can be run on Windows but is not recommended as it can mess up the inferior Windows OS. :wink:
