Sorry for the many questions but im looking for a solution to keep using KDE Apps like Okular (from flatpak) especially under Zorin 17 with changing light to dark mode. In Zorin 16 i had no problems with it, but nowadays it becomes a problem. So i look for a solution to managing the color layout/theme and dont let them interfere each other making it chaotic. See Screenshot below and the themes doesnt work in light mode theres no problem. I use default Zorin 17 so with Wayland btw.
No - at least i didn't make it myself - so if it's not shipped with than no. I'll give it a shot tomorrow and if it worked, mark this as solution or otherwise reply. Thanks for the help!
For evryone with a similiar problem (KDE Apps with missing dark mode and wrong inverting - readability issues) here are some possible solutions:
Stick with outdated apt version (v21.12)
no real dark mode/nightmode but at least it's useable
Use Okular from Ubuntu 23.04 with version 22.12 (from launchpad.net)
you have to download the .deb yourself together with the dependencies (~10 files)
still no real dark mode but newer features
Tipp: KDE shift their apps to nightmode in a experimental state, that you can install as flatpak (still you have to add them from URL) see here (last topic)
right now unstable and not all (Okular missing)
can't say if dark mode inverting in Zorin will work but i expect more than from the normal flatpak version (which is bad in dark mode)
Use the newest version from flatpak but only in light mode (avoid the problem)
