Hello,
Does anyone know why the French zorin forum (zorin.fr) is not responding?
Excuse my English.
Same here:
zorinos.fr is currently unable to handle this request.
HTTP ERROR 500
More info:
net::ERR_HTTP_RESPONSE_CODE_FAILURE
The error message net::ERR_HTTP_RESPONSE_CODE_FAILURE
indicates that there was a problem processing the HTTP response code received from the server. This error can be caused by several reasons, including:
To troubleshoot this issue, you can follow these steps:
Here is an example PHP code snippet that demonstrates how to set an HTTP response code:
<?php
http_response_code(200);
In the above code, http_response_code(200)
sets the HTTP response code to 200 (OK), indicating that the request was successfully processed by the server. You can replace 200
with any valid HTTP response code depending on your requirements. Remember to set the appropriate response code for each request to ensure proper communication between the client and server.
Remember that when setting the response code using http_response_code()
, the response code should not be mixed with manually setting the response code header. Use either http_response_code()
or the header()
function to set the response code, but not both.
When I clicked the OP supplied link, it led to a Zorin Properties Paris real estate page, not to Zorin OS.
The link to https://zorinos.fr/ does indeed give an error.
I'm just wondering, is there any reason to think that the ZorinGroup owns the domain zorinos.fr? I know it looks like it might be related, but similar name does not imply any relation whatsoever so I'm thinking this is simply a completely unrelated domain.
From the "old" Zorin Forum archive: Communauté francophone - French-speaking community. - Old Zorin Forum archive
Perhaps the owner forgot to put 1 Euro in the Meter.
