Zorin Freezing in Browsers - Zen & Brave
Long-term solution would be to change the Wayland settings to false, then go back to autologin. Short fix, drop to tty screen by pressing Ctrl+ Alt+ F3 then you will be asked for your username. If ask for password and still no password set, press Enter key. Next at the prompt type:
startx
This will launch Zorin on xorg/X11.
