tega12
January 27, 2024, 3:26pm
1
I had a problem installing the Zorin OS. I kept on getting Error 5 IO Error.
I ran the following diagnostics
Changed the installation USB. This had no effect
Ran nvme-cli and smartctl both reported that nvme was fine.
Checked disk health from BIOS, no error reported.
Installed Fedora and Ubuntu server this installed without issue.
PC: Asus OLED 14
SSD Info:
20: PCI 300.0: 0108 Non-Volatile memory controller (NVM Express)
[Created at pci.386]
Unique ID: svHJ.HH1M6tPWMm8
Parent ID: Rtk9.JhR1dXh1J9E
SysFS ID: /devices/pci0000:00/0000:00:02.4/0000:03:00.0
SysFS BusID: 0000:03:00.0
Hardware Class: storage
Model: "Intel Non-Volatile memory controller"
Vendor: pci 0x8086 "Intel Corporation"
Device: pci 0xf1aa
SubVendor: pci 0x8086 "Intel Corporation"
SubDevice: pci 0x390f
Revision: 0x03
Driver: "nvme"
Driver Modules: "nvme"
Memory Range: 0xfcd00000-0xfcd03fff (rw,non-prefetchable)
IRQ: 53 (no events)
Module Alias: "pci:v00008086d0000F1AAsv00008086sd0000390Fbc01sc08i02"
Driver Info #0:
Driver Status: nvme is active
Driver Activation Cmd: "modprobe nvme"
Config Status: cfg=new, avail=yes, need=no, active=unknown
Attached to: #41 (PCI bridge)
Status:
I've installed Ubuntu 22.04.3 LTS , added the zorin-os ppa and installed the zorin desktop sudo apt install zorin-os-desktop -y
However, my desktop looks like this
Not sure, whether just adding the Zorin ppa is a proper way to install. Better would be to download the .iso and really install from the scratch.
What about the the live version - did it work?
tega12
January 27, 2024, 11:05pm
3
I ran the live installer, I created the bootable USB using balena etcher and verified the checksum intergrity.
The live installer fails towards the end with the error [Errno 5] - Input/output error
There's no issue with my usb drive or my nvme. I used the same usb and nvme device to install ubuntu and fedora.
I'm able to run a a live session without issues however the installer fails at the end while it copies the files
Did you try another USB Stick? Had a similar problem some weeks ago, it was the USB...
tega12
January 28, 2024, 12:13am
5
I've tried a different USB sticks. I decided to try Zorin OS 16.3, installation worked without any problem. Same machine same USB same balena etcher.
I'll keep using 16.03 for now.
Thanks
OK, that`s interesting. Which Ubuntu Version did yu install successfully?
Don`t forget to mark your solution as solved, so everybody can see you found a solution
Thanks
tega12
January 28, 2024, 9:03pm
7
I successfully installed Ubuntu 22.04 Server and also I was able to install Zorin os 16.3. I attempted installing Zorin OS 17 again and it still failed with the IO Error.
I'm going to keep using 16.03 until I can do an update to 17
system
Closed
April 27, 2024, 9:04pm
8
