Zorin lite 16.2 WIFI issue,and the crazy things we do for our mothers
Hello to everyone,and thanks for your time!
I am a Kali and Minth user on daily bases,so when my mothers elderly 10-ish years old,Samsung laptop started to freeze i thought it would be a great idea to relieve the hardware with a light OS,and here we are.
Zorin works great,response as expected,no issues at all except the WiFi speed,which is about a fifth of the real bandwidth at download,but strange enough,the upload is at full.
The specs are as follows:
-CPU AMD E2-1800/memory 6GB/HDD 500GB/GPU Radeon HD 7340
So what have i done so far in the last few days,except fresh install the OS?
-tried to convince my mother to buy a new laptop,that didn't work
-done update and upgrade
-disabled bluetooth,avoided any use of VPN
-WIFI power management directly disabled (value 2)
-fiddled with Firefox,not much improvement
-installed Brave browser,slightly better
-emulated a VM Zorin on my Mac,WIFI was acceptable
-also installed OS on a separate partition (third device) works just fine
-connected directly thru UTP,no improvement
-the plan is fiber optics unlimited 200/20mbps
-tried on some different networks,same issue.
Below i will share the lshw and lspci data,so knock yourself out,and hopefully together we will find some solution,because i am running out of ideas...
lshw
@katamama:~$ sudo su
[sudo] password for katamama:
root@katamama:/home/katamama# lshw -c network
*-network
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
physical id: 0
bus info: pci@0000:02:00.0
logical name: enp2s0
version: 09
serial: 20:89:84:17:b1:95
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=5.15.0-75-generic firmware=rtl8168f-1_0.0.5 06/18/12 latency=0 link=no multicast=yes port=twisted pair
resources: irq:16 ioport:e000(size=256) memory:d0004000-d0004fff memory:d0000000-d0003fff
*-network
product: AR9485 Wireless Network Adapter
vendor: Qualcomm Atheros
physical id: 0
bus info: pci@0000:03:00.0
logical name: wlp3s0
version: 01
serial: 50:b7:c3:ea:87:27
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list rom ethernet physical wireless
configuration: broadcast=yes driver=ath9k driverversion=5.15.0-75-generic firmware=N/A ip=192.168.0.22 latency=0 link=yes multicast=yes wireless=IEEE 802.11
resources: irq:17 memory:fea00000-fea7ffff memory:fea80000-fea8ffff
lspci
katamama@katamama:~$ sudo su
root@/home/katamama# lspci
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 14h Processor Root Complex
00:01.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Wrestler [Radeon HD 7340]
00:01.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Wrestler HDMI Audio
00:10.0 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB XHCI Controller (rev 03)
00:11.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode]
00:12.0 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB OHCI Controller (rev 11)
00:12.2 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB EHCI Controller (rev 11)
00:13.0 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB OHCI Controller (rev 11)
00:13.2 USB controller: Advanced Micro Devices, Inc. [AMD] FCH USB EHCI Controller (rev 11)
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 14)
00:14.2 Audio device: Advanced Micro Devices, Inc. [AMD] FCH Azalia Controller (rev 01)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 11)
00:14.4 PCI bridge: Advanced Micro Devices, Inc. [AMD] FCH PCI Bridge (rev 40)
00:15.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Hudson PCI to PCI bridge (PCIE port 0)
00:15.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Hudson PCI to PCI bridge (PCIE port 1)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 12h/14h Processor Function 0 (rev 43)
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 12h/14h Processor Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 12h/14h Processor Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 12h/14h Processor Function 3
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 12h/14h Processor Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 12h/14h Processor Function 6
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 12h/14h Processor Function 5
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 12h/14h Processor Function 7
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 09)
03:00.0 Network controller: Qualcomm Atheros AR9485 Wireless Network Adapter (rev 01)
The vast majority of the time, if your Upload speed is normal, but down speed is slow - you need to check your router. If there is any block or interference between the computer and the router or the Router Bandwidth Channel may need to be changed.
I think based on your use-case, Linux Mint Xfce or MATE would have been a good way to go. You get automatic updates and the newer Xfce desktop 4.18 or MATE's recent desktop. Plus Mint sort of has the same paradigm/flow for the most part on all 3 desktops (Cinnamon, MATE, & Xfce). I use Zorin Core about 40% of the time with Mint Cinnamon and LMDE 5 too about 40% with Windows 11 and Tuxedo OS the remaining 20% of the time. Despite like using Zorin a bit more, I think Mint is just a bit better in some areas with regard to their upgrade tool and automatic updates as part of their system. Plus, Mint has found drivers for me in the past with a minimum of fuss. All I am trying to say is although Zorin Core is better for me, their Xfce Lite version I think is not as well done compared to Mint's Xfce which is delightful to use. Good luck!
The latest Mint XFCE is version 4.16.
I didn't want to go long and wide in my description,but ofcourse i checked the router,reseted it,accesed it to check if there is some rogue parameter ...
I downloaded Mate,and will give it a go,so i will check back with the results.
RealTek has been having a few issues in Zorin recently.
You may try blacklisting the ath9k driver and see if it will automatically load the rt8169/8 driver. You could also force this to test.
If it makes it worse, remove the blacklist and return to ath9k.
Nope,same thing. All went by the book,no hiccups but the issue is persistent in Mint too.
I already started browsing for a red Samsung laptop,because i am out of ideas.
Will try,but i am not expecting a lot of a ten years old laptop.
But - the newest update will have 4.18 which is in Beta now.
