Select item is Arrow Up and down
Right, select SECURE BOOT MODE with the arrow keys. Then I think your going to hit the ENTER key to bring up a sub menu on that one, then choose DISABLED. I could be wrong and this is one where you use F5 F6 keys to change its value.
Once thats changed go to BOOT tab, and lets get FAST BOOT disabled. And once you get done doing that next, then press the F10 key to save changes and exit.
Didn't work it is still freezed no key combination or key is working except power key, Can you tell how can I switch back to win 8.1?
You would need to get and install a copy of Windows 8 and then apply any updates and patches.
Otherwise, you may need to try using rEFInd to install zorin OS Lite.
I was installing win 8.1 in fire fox but after 1.5 gb it told download failed. Then retried again download failed. Is there a solution?
I am not sure... But can you please check the Integrity of the Drive (S.M.A.R.T.) and see that it is OK?
I put a lot of effort in support on this one. Since the OP has given up on installing Zorin OS, and is returning to Windows, I will also no longer provide support for this user.
My personal opinion?
Going back to Windows becoming a slave of Microsoft is never the answer, there is always another way.
Good Day
How can I check my disk?
How to turn off tpm?
Marked Solution. 379
