i'm using zorin lite(xfce) , i notice that notifactions appear without sound, i want to get sound in it, i searched in its settings but i don't know where is that option.
Exactly, yes. This is one thing XFCE lacks...
Under "Applications", i can turn volume notification on/off.
To enable event sounds,
Setting/Appearance/Settings.
Have you moved to Lite? I'm asking as your profile states Core.
I thought Event Sounds are like Startup Sounds, rather than notification alerts.
You may try Dunst.
https://forum.xfce.org/viewtopic.php?pid=63653#p63653
VM ![]()
that explains it ![]()
